| | | Forums66 Topics128,046 Posts1,055,618 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2022 Posts: 14 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 14 | I removed the windshield to address separation between the halves at the bottom. Turns out the connecting bar is broken on both sides, between the first and second screws. Any ideas how to get the broken ends out? Thanks! | | | | | Joined: Feb 2000 Posts: 5,199 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,199 | It's not going to just pull out due to rust. You might try drilling down through it to relieve some pressure of the rust, or soaking each end in some Evap-o-rust to see it loosens up. I remember my '37's being a pain to work on. | | | | | Joined: Jan 2022 Posts: 14 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 14 | You're not kidding about the rust! It took several soaks of PB Blaster, vice grips, and a hammer to get out the broken piece! Thanks for the feedback, Joe. | | | | | Joined: Jan 2022 Posts: 14 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 14 | Well, broken connector bar problem solved: since neither end would come out, I wound up driving them further into the frame so the new bars span the holes.
On to cleaning, painting, and reassembly! | | |
