| | | Forums66 Topics128,029 Posts1,055,417 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | I'm thinking about getting a hoist. Anybody got an opinion (thats a dumb question) on a good one? Not going to be lifting any big bolts but don't want to limit it to little foreign cars either. | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | I got the 2 post unit with arms that swing under. My big problem is that it's outside (had to pour a new concrete slab) and will be shoping for one of those RV covers. With the four post/ramp style you can move it around pretty easily inside and out. I think your garage, barn or building is the first issue, just wish I had the bigger shop. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Beware of cheap lifts made in china. I've seen pics of cars seriously damaged after a cheap lift failed. There are a number of quality lifts available. Most 7-10K lb. lifts will set you back over $2K. Personally I'm partial to Bend-Pak.
| | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | I like the "Back Yard Buddy" myself. They will send you a free video if you request it. They talk about the different types of construction of other brands too. Here is the web site. http://www.backyardbuddy.com/ | | | | | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | Let's continue this in the tool shed.... | | | | | Joined: Jul 2006 Posts: 190 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2006 Posts: 190 | I use to install Rotary Lifts for a side job when I was still in the USAF. They were pretty nice lifts. We did quite a few at a Rolls Royce Dealer shop and use to replace the old lifts at Western Autos not to mention quite a small shops and home shops. They are fairly easy to install or you can have them installed. But from what I was getting paid by the guy who I helped install them, it is probably not cheap to have them installed. | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | Recently installed a new Bend-pak Isometric lift in my Brothers new garage , works like a dream ! with the isometric vertical rails you can put up a vehicle and open the doors on most fully . price is reasonable and installation is not bad with a few freinds help to set the rails up ..THEY ARE HEAVY !...and you do need 6" of concrete for this lift. | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | Bend Pak is a well known brand. Many shop use these in my area. | | | | | Joined: Jan 2002 Posts: 30 New Guy | | New Guy Joined: Jan 2002 Posts: 30 | I have a 4-post with casters from Direct Lift. Before I had a commercial 2-post. The 4-post is lighter built but is heavy enough for a 1/2 ton truck and still be safe. You can move it around which is a big plus for a guy with the average size garage. I leave it outside all summer. If I had plenty of room I'd prefer the 2-post because of more accessability to the vehicle. All that said I like it and the price is right. | | |
