1 members (Otto Skorzeny), 81 guests, and 3 robots.
Topics128,024
Posts1,055,395
Members48,422
#158549 11/26/2006 10:51 PM
I'm thinking about getting a hoist. Anybody got an opinion (thats a dumb question) on a good one? Not going to be lifting any big bolts but don't want to limit it to little foreign cars either.
My Trucks
Stuff I Collect
#158550 11/26/2006 11:01 PM
I got the 2 post unit with arms that swing under. My big problem is that it's outside (had to pour a new concrete slab) and will be shoping for one of those RV covers. With the four post/ramp style you can move it around pretty easily inside and out. I think your garage, barn or building is the first issue, just wish I had the bigger shop.
1946 1/2-Ton Chevy
#158551 11/27/2006 1:18 AM
Ex Hall Monitor
Ex Hall Monitor
Beware of cheap lifts made in china. I've seen pics of cars seriously damaged after a cheap lift failed. There are a number of quality lifts available. Most 7-10K lb. lifts will set you back over $2K. Personally I'm partial to Bend-Pak.
#158552 11/27/2006 10:14 PM
I like the "Back Yard Buddy" myself. They will send you a free video if you request it. They talk about the different types of construction of other brands too. Here is the web site.
http://www.backyardbuddy.com/
#158553 11/28/2006 6:36 AM
Let's continue this in the tool shed....
#158554 11/29/2006 12:47 AM
I use to install Rotary Lifts for a side job when I was still in the USAF. They were pretty nice lifts. We did quite a few at a Rolls Royce Dealer shop and use to replace the old lifts at Western Autos not to mention quite a small shops and home shops. They are fairly easy to install or you can have them installed. But from what I was getting paid by the guy who I helped install them, it is probably not cheap to have them installed.
1937 Chevy 1/2-Ton
#158555 11/30/2006 2:36 PM
Recently installed a new Bend-pak Isometric lift in my Brothers new garage , works like a dream !
with the isometric vertical rails you can put up a vehicle and open the doors on most fully .
price is reasonable and installation is not bad with a few freinds help to set the rails up ..THEY ARE HEAVY !...and you do need 6" of concrete for this lift.
1952 Chevy Shortbed
Photos in Photobucket
#158556 11/30/2006 7:25 PM
Bend Pak is a well known brand. Many shop use these in my area.
#158557 12/02/2006 4:56 PM
JJ Offline
I have a 4-post with casters from Direct Lift. Before I had a commercial 2-post. The 4-post is lighter built but is heavy enough for a 1/2 ton truck and still be safe. You can move it around which is a big plus for a guy with the average size garage. I leave it outside all summer. If I had plenty of room I'd prefer the 2-post because of more accessability to the vehicle. All that said I like it and the price is right.
Moderated by  MNSmith
