4 members (1955 1 Series, mason86, moparguy, MNSmith), 103 guests, and 1 robot.
Topics128,068
Posts1,055,883
Members48,428
#149287 11/26/2006 9:06 PM
Having trouble with the screws that hold the rear brake drums in place on my 54. Been spraying them with kroil and smacking them with the impact driver no luck. Are the drums threaded or just the part the screws thread to behind the drum.
#149288 11/26/2006 10:42 PM
I know on my art deco there not threaded in the drum, just the hub. It would seem goofy to thread both. Id assume they are similar. Try getting a big flathead and tapping it on the end with a small sledge fairly hard into the screws, might help???
Good luck, Jeff
My 1953 Chevrolet
1947.1 Gallery
#149289 11/26/2006 10:47 PM
Heat it with a torch. The expansion and contraction should break them loose. If your truck catches on fire.....I didn't tell you to do it though!!
My Trucks
Stuff I Collect
#149290 11/27/2006 1:19 AM
Thanks for the suggestions.
#149291 11/27/2006 2:34 AM
V
V Offline
Good luck!
#149292 11/27/2006 3:48 AM
If you have a torch heat the head of the scew and hit it with you inpact driver as it cools.
The heat will cause it to expand and put a slight strech to it. When it cools it will contract leaving it lose.
The difference between men and boys is the price of their toys.
Grant from Roy, Washington
1956 6100 Chevy Dump Truck in the Gallery
1964 GMC Drump Truck in the Gallery
user
http://s1301.photobucket.com/user/56Taskforce/slideshow/
#149293 12/09/2006 11:45 PM
I've had to use small chisel, carefully aimed at outer edges of slots to start it turning. It messes up screw and will need replacement. Lots of penetrant and heat works too. Sometimes the impact tool works, not always. You can pull the drum and hub as one by removing the axle and big nuts. You just doing brake job? That way hub is out of way for brake work too. You should put in new rear hub seals if you do brakes anyway.
G.L. Grumpy's
Old Iron Ranch
Huntington, IN 46750
MM R tractor, Speedex
and Power King tractors
#149294 12/10/2006 2:24 AM
Was planning to do the brakes and leave the seal alone since they aren't leaking. When i did my 38 the first time I pulled the Drum and hub. next time I'll look and see if they have the 3 screw option. Haven't gotten back to those screws yet.So far have tried the penetrant, Chisel, impact driver. Even tried the ford method....cussed them real good.
#149295 12/10/2006 3:41 PM
I always pull the drum, & hub, as a unit. Part of my preventive maintenace methods. This way you're not only checking the brakes, but you're also checking the rear bearings, bearing races, seals, etc.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
#149296 12/10/2006 10:36 PM
Perhaps thats the way to go, heck with those screws.
