1 members (1 invisible),
100
Mod | | | Forums66 Topics128,265 Posts1,058,366 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 45 Junior Member | | Junior Member Joined: Feb 2006 Posts: 45 | has anybody ever done a diesel swap .. if not does any one have any info on whats the best motor to swap in to a stovebolt and such.. thankyou derek | | | | | Joined: May 2006 Posts: 237 Shop Shark | | Shop Shark Joined: May 2006 Posts: 237 | I like the sound of a detroit 6-71, but not many bolts have an engine big enough to accept that much engine.
Someone on this board is putting a detroit 4-53 in their "big bolt". It's looking like a slick setup. He custom fabbed mounts, and you'll have to make sure you have a front axle that can hold that weight.
I don't know if one of the cummins B series will fit or not. | | | | | Joined: Feb 2006 Posts: 45 Junior Member | | Junior Member Joined: Feb 2006 Posts: 45 | i hope one day to do a turbo diesel that would be sick to throw a detroit diesel... also did chevy have a diesel engine out back in the 1950s i dont think sooo right b.c companys like cat and detroit where into that feild of production ? thankyou derek | | | | | Joined: May 2006 Posts: 237 Shop Shark | | Shop Shark Joined: May 2006 Posts: 237 | Check out this link... to this site! http://www.stovebolt.com/gallery/stone_moe_1959.html Now THAT is a bolt. I belive that GM was the first to make the 2-stroke diesel and they sold the production rights to detroit diesel. I think I could fit a 4-53 or 3-71 in my engine bay, but I'd need to beef up the front axle a bit. Even then, I'm not sure it would out torque a well built 292, which will fit in with far less money and effort (from what I've read). That's what I'm thinking about for my rig. I've heard they are casting cross flow heads for the 235 / 261 and for the 250 / 292. I don't think they are available yet... but put a blower on a built 292 and you'll have to start strengthening other things to handle the torque. | | | | | Joined: Feb 2006 Posts: 45 Junior Member | | Junior Member Joined: Feb 2006 Posts: 45 | wow thats a sick bolt... i want to do stacks at the very least to my chevy 3800 but yea diesel would be nice lol maybe ill jus work my stoc 235 .. ? | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | I want to put a 6-71 in my 41 big truck. Its far enough gone (frame/running gear wise) Im gonna look for a 60s ish crackerbox and swap the cab onto it. Way to far in the future to think about... Detroits are some of the best made engines. They sleeve the cylinders so as long as you dont punch a hole in the block you can always rebuild em. | | | | | Joined: Oct 2004 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2004 Posts: 47 | A friend of mine was looking to swap a diesel out of one of those frito-lay cube trucks. Makes sense to me. A full load of potato chips must weigh.. what.. 300 pounds? High mileage, sure, but it probably never worked very hard.
-Joel
'52 3800 Panel School bus conversion... Glass all around. (check the gallery!)
outside of a dog, a book is a man's best freind. inside of a dog it's too dark to read. -Groucho Marx
| | | | | Joined: May 2006 Posts: 237 Shop Shark | | Shop Shark Joined: May 2006 Posts: 237 | Rustednuts,
Those crackerboxes were essentially cab overs. I've seen them for sale for about $2000 in "fair running" condition, but I don't know if you could fit a bolt cab over that frame. It'd be neat to sea though. They WILL last forever if you don't send a rod flying and maintian them well. I've heard they are tough to maintain though.
Joel,
I've heard those frito-lay trucks are the ones to get the detroits from for exactly the resason you mention... they've led an easy life. Did they have 4-53's?
I'm still thinking a 292 is the right thing for me. While I like diesel, I'd prefer a gasser 1 ton. If I ever got a 3 ton or so (like is in the for sale section right now) I'd definitely want a diesel. I'm thinking a 6-71 with 13 speed road ranger would be fun. | | | | | Joined: Jun 2006 Posts: 687 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 687 | I believe detroit had a 3 cyl diesal aluminum block in the 40's that was use in troup transports and 2 ton jeep trucks.
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson" | | | | | Joined: Nov 2000 Posts: 119 Member | | Member Joined: Nov 2000 Posts: 119 | The F-L trucks I have seen had 4-cyl Perkins engines. Have driven one with same. OK if you like extremely slow acceleration, a lot of noise and 55 mph top speed. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | A little info on the Detroits- Detroit Deisel was a division of GM, with design and testing of the 2 stroke engine stating around 1932, with production starting in '35. The original use for the engine was deisel locomotives. GMC offered it in trucks in '37/'38. Chevrolet didn't get a deisel until the '60s. Detroit Deisel engines were manufactured with both iron and aluminum blocks. They were also sold as Grey Marine engines for use in Navy vessels. The numbering system refers to the number of cyliders and the displacement of each cylinder, example-6-71= 6 cylider/71 cid per cylinder, 426 cid total displacement. These engines range from the 2-53 used in John Deere 420/430 to 12-110s that are usually found attached to hospital generators. This is also where the numbering for the aftermarket superchargers came from, as many early rodders used blowers from these engines.
Bill Burmeister | | | | | Joined: Apr 2001 Posts: 439 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 439 | Thats really interesting Bill. Thanks. | | | | | Joined: Nov 1995 Posts: 5,762 24601 | | 24601 Joined: Nov 1995 Posts: 5,762 | Howdy mazdabon2nd We have a couple of Bolters who have done, or who are doing, diesel swaps. Grigg Mullen is in the process of putting a Detroit into an AD Big Bolt right now and has several threads about it in the Big Bolt forum. The latest update is located at this link A 3800 with a small Detroit would be cool. I have kicked around an idea of getting a Cummins and tranny out of a Dodgebolt but that one's never really gone beyond the idea phase... Regards, John
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Jan 2002 Posts: 622 Member | | Member Joined: Jan 2002 Posts: 622 | That 59 GMC rocks! Well, except for the diamond pattern on the front bumper... Can't we discipline them for doing that?
delete my account and pictures
| | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | This thread more properly belongs in the Big Bolts forum so I am moving there. I let it run thinking it would die out quickly but obviously it hasn't so it now goes where it belongs. | | | | | Joined: Oct 2006 Posts: 8 Junior Member | | Junior Member Joined: Oct 2006 Posts: 8 | It sounds like a pretty big diesel can be "wedged" into a 1954-55 first big truck,say a 4400.I have found a deluxe model(5 window, radio-equipped,airflow fresh-air heater,stainless window trim,transport blue with 2-tone interior, etc).It is a "shorty" dump truck---110" wheel-base?(Dump is only about 6'long?)What is the biggest,baddest, torquiest monster I can put in there?I'd like to throw some stacks on there.And did these puppies ever have hydra-matic trannies?Can one of these diesels be mated to a Hydra-matic?I have a spare 1954 Hydra-matic tranny.(I was saving it for an extra for my hydra-matic 54 pickup)Thanks, Rich | | | | | Joined: Oct 2006 Posts: 8 Junior Member | | Junior Member Joined: Oct 2006 Posts: 8 | PS...I forgot to mention this truck is a COE. Does that change anything? I believe it's a 1 1/2ton (4400)...Rich | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Rich, A 110"in. wheelbase '47-'55 Chevy COE, will be a 5100 series. If it's 16000lb. gvw. It will be a 2 ton. Sounds like a good candidate for a Orig. Resto. You don't find them equipted like that very often. You also don't find the short 110"in 5100 series trucks that often. Got any pictures of it. I'd like to see it. Chevy never installed Diesels, in any of there '47-'55 COE's. GMC only installed Diesels in the Heavy Duty "Cannonball" COE's. | | | | | Joined: Feb 2006 Posts: 222 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 222 | Hi! As John said, Grigg is in the process of putting a diesel into a big bolt. He usually shows up on weekends. If he doesn't show up, chase him down, he is a wealth of information. Rick In VA | | | | | Joined: Oct 2006 Posts: 8 Junior Member | | Junior Member Joined: Oct 2006 Posts: 8 | Spanky...Thanks for the info. I took pictures of this beast. It's cute, if that's possible. I'll try to get them on here soon. It's so original, that even the original grease markings are still on the firewall! Thanks, Rich | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I know of a guy that stuffed a 3208 Cat into a 75ish 1 ton dually way back when. With some tools and talent I'm sure it could be done to a bigbolt too. I wish I had the funds to try it, Scott | | | | | Joined: Jul 2006 Posts: 707 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 707 | I can't think of a good reason to overload the steering axle of a 1-ton like that, 48. And having lost some 30% of my hearing to 2-stroke detroit diesels in the far past, I won't be doing too much of that any more - although I do love the sound of those awful things, and will take any opportunity to put in an hour or two with a Jimmy. However, I am looking very closely indeed at the Cummins 4BT. If I do go that way I'll have to import one, because for some unfathomable reason there aren't any up here. Maybe they're all still working. I assume that, since most of their parts are interchangeable with the Dodge Cummins, I'll be able to use a Dodge flywheel, clutch & 5-speed with the 4BT. Comments, anyone? 1951 3800 Be the change you want to see. -hotshoe
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I think y'all are on the right track, I always recommend a 4BT as the most practical and simplest swap for our trucks. (although I have not done it, only thought about it) However, if you have a COE a 6 cylinder like from the dodge trucks would probably be a better choice for the better power and more room available.
I was considering a COE for my diesel, but I decided I wanted better accessibility for working on things. I may be wrong, but I think a normal truck will be easier to work on, like to adjust the valves.
As for overloading my front axle, it is from a Chevy 3500HD with a v8 diesel, and is rated for plenty more than I will ever have on it. The weight in the front axle in the truck it came from is more than what mine will be. It is also physically larger and stronger looking than the 2 ton axle I took out. And the noise, I am going to do everything I can possibly do to insulate the cab from sound. I will also have the exhaust come out at the rear wheel on the right side. A good muffler will help too. | | | | | Joined: Nov 2004 Posts: 2,432 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,432 | About a month ago, I ran into a guy who had a diesel in his '51 or '52 half ton. I took some pictures of the outside of his truck, but he was working at the time, and did not get to see the engine compartment. He was a mechanic for a diesel shop in Beemer, Nebraska. He had a '47 with a for sale sign in it parked along the highway, that was how I met him. So, they have been put in half tons. I didn't get around to asking him if he is a "Bolt" member.
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | |
