Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
1 members (TexasFarmTruck), 189 guests, and 4 robots.
Topics128,282
Posts1,058,497
Members48,490
#146036 03/10/2006 11:41 PM
Junior Member
Junior Member
I have a 49' Chevy 6400 that I still use to haul hay. The problem is the electic fan I put on it is to small. I put a new radiator in it with no help. What is the biggest electric fan I can get and where can I get it. Any help would be nice.
#146037 03/11/2006 12:12 AM
Jed Offline
Coondog,
don't really have an answer for you, but perhaps an alternative.
Alot of the street rod guys I know have two of the smaller fans mounted in a diagonal fashion in front of the radiator.
Seems to work for them, as none of them have reported a problem with overheating.
#146038 03/11/2006 12:59 AM
have you checked your water pump?
#146039 03/11/2006 2:40 AM
There's got to be a reason it runs too hot. I have a 350 in my 1 1/2 ton that pushes a plow while hauling 4 tons of traction with an original 48 radiator and the 350's original fan clutch. It never runs hot. There must be a flow problem somewhere, feel the radiator from top to bottom after it's gotten warm, looking for cool spots.
Just a thought,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#146040 03/11/2006 3:27 AM
I
I Offline
Your trouble might also be the timing of the engine, just a little too much in retard or advance will heat one right up. If you cant find any trouble in the cooling system or a blockage there, timing is the next place I would look.
Jeff
1947 Chevy 6400 2-ton
1953 3/4-ton
It was fun while it lasted
#146041 03/11/2006 5:22 AM
You might look to see if it's sucking the radiator hose flat;if so,you can run a spring down it to keep it from collapsing,or switch to a piece of pipe with a piece of radiator hose at each end to couple it to the radiator and the engine.
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
#146042 03/12/2006 5:38 PM
Riding in the Passing Lane
I get an electric fan from Summit. It is 16 in. & pulls about 2700 cfm. It,s a little pricey, about $210. It comes with mounting brackets (no hanging on radiator core) & adjustable therm. I used one on a 56 & worked well. I just got another to put on my 70.
1972 Chevy c10 Cheyenne Super
#146043 03/15/2006 2:36 PM
Junior Member
Junior Member
Thanks for the suggestion guys!
