0 members (),
258
Mod | | | Forums66 Topics128,077 Posts1,056,013 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2003 Posts: 13 Junior Member | | Junior Member Joined: Mar 2003 Posts: 13 | I have a 49' Chevy 6400 that I still use to haul hay. The problem is the electic fan I put on it is to small. I put a new radiator in it with no help. What is the biggest electric fan I can get and where can I get it. Any help would be nice. | | | | | Joined: Apr 2004 Posts: 703 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 703 | Coondog,
don't really have an answer for you, but perhaps an alternative.
Alot of the street rod guys I know have two of the smaller fans mounted in a diagonal fashion in front of the radiator.
Seems to work for them, as none of them have reported a problem with overheating. | | | | | Joined: Oct 2003 Posts: 363 Member | | Member Joined: Oct 2003 Posts: 363 | have you checked your water pump? | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | There's got to be a reason it runs too hot. I have a 350 in my 1 1/2 ton that pushes a plow while hauling 4 tons of traction with an original 48 radiator and the 350's original fan clutch. It never runs hot. There must be a flow problem somewhere, feel the radiator from top to bottom after it's gotten warm, looking for cool spots. Just a thought, Scott | | | | | Joined: Nov 2005 Posts: 355 Member | | Member Joined: Nov 2005 Posts: 355 | Your trouble might also be the timing of the engine, just a little too much in retard or advance will heat one right up. If you cant find any trouble in the cooling system or a blockage there, timing is the next place I would look. | | | | | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | You might look to see if it's sucking the radiator hose flat;if so,you can run a spring down it to keep it from collapsing,or switch to a piece of pipe with a piece of radiator hose at each end to couple it to the radiator and the engine. Speed | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I get an electric fan from Summit. It is 16 in. & pulls about 2700 cfm. It,s a little pricey, about $210. It comes with mounting brackets (no hanging on radiator core) & adjustable therm. I used one on a 56 & worked well. I just got another to put on my 70. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2003 Posts: 13 Junior Member | | Junior Member Joined: Mar 2003 Posts: 13 | Thanks for the suggestion guys! | | |
