8 members (Mike B, WICruiser, Youngin' Tut 59, Pete1946, Bizaircon, klhansen, LuckyLee, 1 invisible), 72 guests, and 1 robot.
Topics128,140
Posts1,056,770
Members48,454
Apprentice
Apprentice
When building my 49S10 with 350V8 I added a serpentine belt drive from an 89 Caprice. Recently, after changing out the AC compressor I have developed a belt squeaking noise. I did notice it occassionally before changing the compressor but it is all the time now. I can treat it with belt dressing and it will go away....for awhile and then starts up again. I have checked the alt., ps, water pump, and ac compressor and all are rotating freely. I even changed the belt tensioner pulley but to no avail.
The tensioner seems to have plenty of resistance on it. I also noticed some fine rubber shavings but cannot find anywhere that seems to have interference with the belt. Any ideas on what might be causing this? Thanks.
I would say it's the aftermarket belt. When the cheaper belts run their backs against a smooth pulley, they get buffed and glazed. When they "walk" across the pulley after they get glazed, they make that noise. I try to use factory belts or the pricier aftermarket belts without much printing on the smooth side. Belt dressing is just a temporary diagnostic tool, it won't cure belt noise.
Just my 2 cents worth,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Apprentice
Apprentice
Thanks 48bigtrucks-
I have replaced the original belt with a Gates belt but maybe I need a better one. The only smooth pulleys on this set up are the tensioner pully (new) and the water pump pulley. Would it make sense to lightly scuff the surface of the water pump pulley to see if it will "grab" better? Just fishing for ideas here.
1 Offline
I had the same thing happen on mine (86 C20 w454), I was getting the fine rubber shavings also and the squeaking noise was driving me crazy I changed the tensioner pulley and it still squeaked, What I finally did was change the belt to a 1" smaller belt and it went away completely ! no more squeaking or rubber shavings ?? I don't know why BUT its been over 7 months and I drive it everyday and still no problems.
I also installed a serpentine set up on my 51 and ran the smaller belt... so far no problems
Its worth a try
Good luck bro.
Todd
Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs.
1951 3100 350 TBI Gallery Toddzilla... "$old"
you can scuff sand the back of the belt while its running (mind the fingers + tie eek ) that will usually fix the problem. ohwell
Also check belt and pulley alignment-will make noise
if as little as 1/4" out of alignment.
GMC: Get More Cash...
1958 GMC
My Webshots photos
