Good morning, I am going to be periodically jacking up my truck in order to use a rolling car dolly under each wheel, and was curious about a proper jacking point for the front of the truck. I'm a little hesitant to put the jack under the front axle. Can anyone help me with a good jacking point?
-Patrick 1953 Chevrolet 3100 261 / 4-speed / 4:11 / Commercial Red
If you're using a bumper jack, jack at the bumper bracket attachment location. If you're using a floor jack use the frame rail or cross member. It would help to know what vehicle you're referring to.
Is there a problem with using the center of the front axle?
~ John
1949 Chevrolet 3804 In the Legacy Gallery | In the Gallery Forum 1973 IH 1310 Dump 1963 Kaiser M38A1 2001 International/AmTran RE3000 "Skoolie" 2014 Ford E-350 4x4 (Quigley)
I got tired of jacking both ends of my vehicles up to put them on dollies. I got a set of lifters from Harbor Freight when they were on sale. I use my dollies for engines and transmissions now.
I use the center of the front axle on my 1954 3604, never a problem.
Ron - - Dusty53 1954 Chevy 3604 In the Gallery Forum "You can't dance with the Devil and then wonder why you're still in Hell." "They will forget what you've said, and they will forget what you have done but they will never forget the way you made them feel."
Yea I've seen those at Harbor Freight, they are about double the price of regular dollies, that's my only hesitation. I didn't know if using the center of the axle was a good idea or not.
You can haul a 1000 pound engine and transmission down a road with knee deep pot holes and never harm the front axle---I wouldn't worry about lifting with a jack. In 1953 this truck was designed to haul rolls of wire, steel fence posts, and you name it down unpaved roads and across farm fields. They are not delicate flowers.
A lot less jacking if you use the center of the front axle. If that would cause any kind of damage whatsoever, we should all just shove these trucks in the ditch right now.
I always lift the of my 50 4100 from the center of the front axel, but I use a short 2 x 4 to spread the load out a little. The rear is more difficult since the diff is offset from center.
They are definitely not delicate, not fragile in any way. Pull up my posted picture of 54 Chevy T boned new 1996 Suburban. That was at 53 or 54 m.p.h., still has the same front axle. That old 3100 almost tore the 3500 Suburban into. When I was a kid the pulpwood people would get the front axles from 55.1 back to use as end trailers to carry extra long pine trees in the woods. They would weld the steering knuckles, put two heavy drag chain's on welded hooks and drag HEAVY stacked pines lying on them until they got to a dirt road. If one has ever seen the back Piny woods and palmettos in Florida you know its rough. I still have one in the back pasture. Did not mean to make a narrative here but when one goes to a car show you may see one Ford of the same era and 15 of our old boys. I always jack mine up at the axle and spring cross. Doc.
This is a little off the original topic but relates to the mention of dollies. I purchased the kind that you used a jack to lift the vehicle on first and was not happy with that whole process or how hard it was to move the car once on. I sprung for the HF go jack version. I must say I am very pleased with them. Even pushing the 3800 around is easy by myself. https://photos.app.goo.gl/WrHyKXakyut886SS7
~ Billy Old Dominion Stovebolt Society: Exotic Animal Division 1946 Chevrolet Cab Over Engine | In the Gallery | Video | More pictures 1959 GMC 860 | Pictures 1950 Chevrolet 3800 | Pictures I've got a trailer and I'm not afraid to use it!
