2 members (Rusty Rod, porsche),
64
Mod | | | Forums66 Topics128,021 Posts1,055,357 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 84 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 84 | I have a 66 C10 with 283 2 bbl & 3speed and am thinking of upgrading to add a little snazz and couple hp. Plan is change over to 4 bbl with alum intake and maybe holly carb. This has manual choke. any thoughts on this? also considerations on the egr. What should I buy here. Comments welcome from the experts. Gary
GS
| | | | | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | Hi Gary The Edelbrock Performer manifold would be a good choice.If egr isn't required by law in your state I wouldn't bother.Keep in mind you will want to change the cam too.A 4bl on a 2bl cam wouldn't be all that good. | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Unless you're going to drag race, I would opt not to use the Holley. Find a Edelbrock or a Quad to rebuild instead. Just my opinion but Holley's are a pain for the street, Scott | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | | | | | | Joined: Dec 2002 Posts: 3,438 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,438 | buy the edelbrock kit, comes with a cam, intake and carb... works very well...
| | | | | Joined: Mar 2006 Posts: 262 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 262 | I put an Edelbrock 600 cfm on my 283. Also an RV cam. Works great!
My truck: She may not be the prettiest girl at the dance, but she's all mine!
| | | | | Joined: Oct 2006 Posts: 84 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 84 | Hey guys. Thanks for the great tips. Gary
GS
| | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | Keep the carb on the smaller size. Too big will just suck gas and have poor performance
500 to 600 CFM is more than big enough for a 283. | | | | | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | Rustyrod has the right idea-the kit is designed to work together. And the main problem with Holley carbs is that they're so adjustable,and being tinkerers by nature,rodders tend to adjust a lot of stuff they don't know the actual function of. I talked to a tech at the Holey Carb trailer at the races a couple of years ago,and he said 98% of what he had to do to "un-f**k" the Holley carbs brought to him consisted of adjusting EVERYTHING back to specs and replacing the occasional power valve or accelerator pump. Personally,I've never had any problem with Holleys except I could never get better than 10 miles per gallon with one. Speed | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The Edelbrock manifold is a good package. If you want to save money & can rebuild a carb yourself you can find a Q-jet at a swap meet or pull your own parts lot real cheap. You can put in an electric choke if it doesn,t have one. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Q-jets are perfect for 283's, that's what they were designed for originally.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Mar 2005 Posts: 24 Apprentice | | Apprentice Joined: Mar 2005 Posts: 24 | I'm putting an edlebrock c-26 dual quad intake with offy cross ram adaptors and two 600 cfm edlebrock AFBs on my 283...but I'm totally nuts.
Also got a comp cam, roller tip rockers (1.5 intake and 1.6 on exhaust), new timing set, reworked power pack heads with 1.82 intake valves and hardened exhaust seats. I plan on using a progressive linkage and will dial in the carbs with new rods and jets.
I'll round off that bolt head....just as soon as I'm done strippin' this screw!
| | | | | Joined: Dec 2006 Posts: 8 New Guy | | New Guy Joined: Dec 2006 Posts: 8 | I've a couple of years experience with this stuff and find that I get more bang for the buck with a free flowing exhaust as the first step. Then second is a cam that will get the F/A mixture moving into and out of the cylinders. Don't overdo the cam. This is a truck and you don't want to kill the low end torque. Now if you find that your starved for F/A then upgrade the intake. | | |
