8 members (Ponchogl, Peggy M, Gray_Ghost, David Bush, TooMany2count, Tronman, JW51, Wayne67vert), 94 guests, and 2 robots.
Topics128,052
Posts1,055,716
#135576 10/04/2006 11:27 PM
Junior Member
Junior Member
does any body know of a lift kit that will fit or work for a 1951 chevy 3800 1 ton
#135577 10/05/2006 2:41 AM
None availible for that year, most of what's on the market are for '68 and later, exept for Jeeps. Most likely, you'll either have to find a shop to fabricate it for you or fab your own.
Bill Burmeister
#135578 10/05/2006 3:22 AM
As in suspension/body lift or a dump bed type of lift?
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#135579 10/05/2006 3:33 AM
Junior Member
Junior Member
suspension lift
#135580 10/05/2006 4:05 PM
Option #2- Measure your springs, find other make/ model with same size springs and install.
1965 Chevy C-10 Longbed Stepside
#135581 10/05/2006 10:41 PM
Junior Member
Junior Member
thats what i though i was gonna have to do thank you guys for the help
#135582 10/08/2006 3:41 AM
I had springs made for my 52 1 ton with different ride height.
I used Eaton Detroit spring, they are very knowledgeable and helpfully. I would use them again over any other spring shop I have seen or know of. They even have the factory blueprints for most all original leaf springs, including our 1 ton trucks.
1952 Chevrolet 3800 pickup
---All pictures---
#135583 10/09/2006 6:30 PM
Junior Member
Junior Member
do u know where there located can you give me some more info
