2 members (TUTS 59, 1 invisible),
120
Mod | | | Forums66 Topics128,026 Posts1,055,406 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 45 Junior Member | | Junior Member Joined: Feb 2006 Posts: 45 | does any body know of a lift kit that will fit or work for a 1951 chevy 3800 1 ton | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | None availible for that year, most of what's on the market are for '68 and later, exept for Jeeps. Most likely, you'll either have to find a shop to fabricate it for you or fab your own.
Bill Burmeister | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | As in suspension/body lift or a dump bed type of lift? Scott | | | | | Joined: Feb 2006 Posts: 45 Junior Member | | Junior Member Joined: Feb 2006 Posts: 45 | | | | | | Joined: Mar 2003 Posts: 181 Shop Shark | | Shop Shark Joined: Mar 2003 Posts: 181 | Option #2- Measure your springs, find other make/ model with same size springs and install. | | | | | Joined: Feb 2006 Posts: 45 Junior Member | | Junior Member Joined: Feb 2006 Posts: 45 | thats what i though i was gonna have to do thank you guys for the help | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I had springs made for my 52 1 ton with different ride height. I used Eaton Detroit spring, they are very knowledgeable and helpfully. I would use them again over any other spring shop I have seen or know of. They even have the factory blueprints for most all original leaf springs, including our 1 ton trucks. | | | | | Joined: Feb 2006 Posts: 45 Junior Member | | Junior Member Joined: Feb 2006 Posts: 45 | do u know where there located can you give me some more info | | |
