4 members (Peggy M, Gib70, Gray_Ghost, 1 invisible), 252 guests, and 2 robots.
Topics128,089
Posts1,056,117
Members48,434
Building a 35 pickup street rod with a ford 289 engine. Would like an easy wiring kit for this application.
I was impressed with an EZ-wire brand kit that i put in my last truck, very simple.
Junior Member
Junior Member
I used a kit from Its-a-snap in my last rebuild. Also their power window's. Good quality and good prices. I plan on using the same in my 41 plus their windshild wipers. Check out there ad in the truck mags. I am also going to use their instruments.
I used the 12 circuit harnes from Hot Rod Wires on my '56 3100. I plan to get another for my '54 GMC.
Junior Member
Junior Member
My son used the EZ wiring 21 circuit system in the 50 Chevy sedan he is restoring. I was impressed with the quality and price of the unit.
Z
Z Offline
I also used the ez wiring 21 circuit system and it worked really well, was well labeled on all the wires and had a nice selection of wiring to do all kinds of upgrades if you wanted like power door locks, windows, and third brake etc.
1946 Chevy Pickip
Ron Francis is a good brand...remember you get what you pay for. You just call them up, tell them what your building, they will ask you some specific questions and then send you the wiring harness to work with motor & charging system.
I ran an EZ Wiring 21 circuit system in my '63...worked great.
Daily Driver 63 C-10 LWB Fleetside
I also used the EZ Wire kit. Very simple, excellent quality, good instructions, and half the price of the others. Why wouldn't you use it?
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
Painless has the tech staff to back up their product.
Joe smile
I also used the EZ wire unit, simple and well marked wires. Would definitely use again.
painless or ron francis wiring...both are fairly headache free. Check out madelectrical.com
this oughta be in electrical
Jim & Caroline
Jim -
Your right! But, Painless still has the best tech support.
Joe smile
I used a generic 12 circuit Painless harness in my 29 Model A pickup this past summer. It was a lotta work, but it was less than I had originally anticipated. Once I got the fuse box mounted and started running bundles of wires in the general direction that the were to go, it wasn't bad at all...just time consuming.
Now I have the whole thing converted to 12v, with halogen headlights and turn signals (and brake lights) in the stock housings. If I were to do it again, I'd go with another Painless kit, just cuz I'm familiar with their layout.
One thing I really liked was having each wire marked with its circuit number and name. That was a BIG help. The other thing I ended up doing was installing a ground bus near the main "Maxi-fuse" so that I didn't have to rely on frame or body grounds. I'm hoping this will pay off in the long run, especially when I use the "A" as a salt flats pit rat.
There are pics of the whole adventure on my website, which is in my sig.
I have toured the Painless Wire facility and know several of the owners and tech people there. Even though I have not personally used the product, I know people who have and I know people who install the product. I have never heard of a serious problem and the ones I have heard of were solved almost instantly. Of the installers I know, they all say once you use Painless, you'll never go to anyone else's. What I found intersting is their test facility where they actually research wiring and electrical components and the effects they have on vehicles!
No - I don't work for Painless and I am not a spokesperson for them, but I know a good product when I see one!
Joe smile
Joe, they may be all that but their rep at the swap meets gave me the cold shoulder when I was shopping for a harness. I then visited the Hot Rod Wires booth. The guy was very helpful, very knowledgeable and builds a very good harness. The wires are larger than they have to be and plenty long. And a lot less expensive than Painless. I'm very happy with the one I put in my '56 and as stated above, intend to put another in my '54.
I built my own.
Another quality post.
Real Trucks Rattle
Apprentice
Apprentice
I've used Ron Francis twice and EZ Wire once. While the RF is a more complete and custom kit the EZ Wire is adequate and less costly. RF has you terminate the wires at both ends and this allows for a cleaner, easier routing in my opinion. RF also has more complete and detailed instructions if thats what you need. It is hard to beat EZ Wire on cost.
Company called "EZ" wiring. Aircraft qaulity, color coded, marked every 5" and cheap at around $160.00. I like mine.
Jesus is Love! Never forget the Veteran.
AND God bless Amercia!
Sounds like the EZ 21 wins for my 64. Is the official web site (with the red car in front of the barn) the best place to order it from? Thanks, Scott
