4 members (Gdads51, carbking, David Bush, 52Carl), 82 guests, and 9 robots.
Topics128,078
Posts1,056,029
Members48,433
#134439 06/02/2006 2:19 AM
I hate the gas tank behind the seat in my 65 pickup (shortbed) :confused: . Anybody got any ideas for a different setup other than the 21 gallon between the rails setup that you see advertised in all the restoration parts catalogs?
I wanted to see if anyone had swapped anything of a junkyard vehicle. If so what? maybe side saddle or something out of a van or blazer? Dual tanks???? Come on brains , start workin!!!! :confused:
#134440 06/05/2006 11:21 PM
Junior Member
Junior Member
I used a RCI 16 gallon Fuel cell with sending unit. I bought the tank on ebay. An option maybe
#134441 06/06/2006 4:01 AM
LMC makes a conversion kit to install it between the rear frame rails. Comes with a sender, straps and some hardware. Check it out,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#134442 06/13/2006 11:55 PM
see
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=22;t=005514;p=1#000002
i used a 16 gal univ tank, 14 gauge. this done on a 51 3100. this puppy ain't going nowhere.
there is room under the bed, just behind the cab, w/ the filler neck just infront of the pass rear fender and the tube fits above the frame rail to fit a spout. my spout is the old cab spout turned 180 degrees, welded a (muffler pipe) flare of 2'' to the 1 1/4'' stock filler tube to a gas hose into the 2'' muffler pipe of the gas tank. it hangs off the cross bed rails using 1/2'' all-thread and two 13'' under tank steel bars. all locktite'd and double nutted.
see pictures.
Jim & Caroline
#134443 06/14/2006 12:15 AM
On my 65 I plan to add a fuel cell between the rear frame rails where the spare would go. I have seen guys put Blazer/ Suburban tanks back there. I had a 66 C20 that had dual saddle tanks mounted. It was a very clean mounting job. The tanks were installed on the truck back in the late 60's and were made of heavy gage steel. They had locking fuel doors cut into the bed. It had a switch on the drivers side floor to switch the tanks. I saw a lot of pre '72 trucks out in the western states with that added to them.
1965 Chevy C-10 Longbed Stepside
#134444 06/14/2006 5:29 AM
Thanks for all the replies guys...ill see what i can come up with. If i find anything interesting at the junkyard ill let you know on a post sometime in the future!
#134445 06/19/2006 11:07 PM
I used a fuel tank from "B" body mopars for a between the rails tank on the rear of my 57 and 58 trucks. Had to run a mopar fuel pickup and sending unit and a seperate fuel gauge. I believe I remember my 70ish pontiacs had the same rear center fill as the mopars and might be a good fit.
Jim
Good luck with your project!
#134446 01/03/2007 3:19 AM
Apprentice
Apprentice
i was thinking of the spare tire kit and have the fill neck go out behind the liccense plate like the old cars had. anyone seen this done?
#134447 01/05/2007 12:54 AM
Junior Member
Junior Member
hey new guy hear , had a 62 short stepside , bought a 20 gal. tannk and straps from a 1986 buick regal fits right under back rails ,you have to fab some extentions for the back of the straps filler neck comes out center of the bumper works well plus adds weight to the back of your truck
Billy Payan
#134448 01/06/2007 2:51 PM
Junior Member
Junior Member
any photos of your installation of the regal tank?
my bumper is set up with trailer ball etc and i'd rather not have filler right there. was there enough room to add a turn to fill from either the side or from the bed?
also, what did you do for sender?
any reason this wouldn't work with what's essentially a '64 gmc shortbed with leaf rear?
thanks
bill
bill graham
#134449 01/07/2007 2:25 PM
Junior Member
Junior Member
the regal tank exit center of bed you could probly find one with filler neck on the side, I ran a new wire all the way back one hot to the sender one ground to frame installed new after market gas guage in console
Billy Payan
#134450 01/09/2007 8:39 PM
Socket Breaker
Socket Breaker
http://www.persh.org/pickup/IdeaPage.htm
Fuel Tank Items
Gas Doors for Fleetside w/ saddle tanks
Gas Cap for Stepside w/ rear mounted tank
Cheap Custom Gas Cap
How to put a GAS TANK under your BED
a few ideas other folks have used.
-W
