Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
9 members (DoubleB, Hotrod Lincoln, Tiny, Rosco, smeyer6, SNOYL, frogfarmer, ShopRag, Dakota Bob), 143 guests, and 1 robot.
Topics128,292
Posts1,058,590
Members48,492
Here are a few pics of mine so far:
1: Hurst T handle
2: air cleaner
3: mirror
It's gotta be this drip catcher.
I'm not sure about VERY favorite, but I'm really glad I installed a dual reservoir master brake cylinder! Oh, and the heater, which I need to connect to the engine soon.
Tim
I am currently digging back in to a 1953 3800 (one ton) with a nine foot bed. I've owned it since 1979, and drove it until 1982 (or so). My wife got me involved in restoring it back in 2002, got the body removed and the frame redone, then things came up. Now I am retired and starting again. If anyone is interested I have photos on Imagur ( https://timwhiteblues.imgur.com/ ). I live way back in the woods in the Ozarks on 40 acres at the end of a 2 1/2 mile private road.
Tim
This...
T5
BC
1960 C60 pasture art
My favorites so far are the 5x7 mirrors on stock arms. So much better than the original small round ones, you can actually see what's back there when backing or checking traffic. And of course the T5 transmission. If your AD is fairly stock and a true driver, you really should check into this fairly easy and (relativity) inexpensive upgrade.
No specific images of the mirror upgrade, but the ones below gives a good idea of how they look.
RonR
1970 340 Duster
1964 CJ5
Radial tires on original wheels.
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
non-stock - non-original options/accessories:
both trucks with all 6v equipment
1954 Suburban:
1960 261 (with spin-on oil filter) and GMC 270 2-barrel carburetor
seat belts on both rear seats
front seat need seat/shoulder belts
SM420 that was available but not stock/standard (added later by me)
shift pattern on shifter knob
3.55 Ring & Pinion
radial tires on original wheels/rims
stainless steel brake lines
1954 5-window 1/2-ton deluxe 3104 pickup
shoulder/seat belts
3.55 Ring & Pinion
original number-matching transmission/block with "848" head, and, with cam and valve modifications
Does anyone have cupholder pics?
Turn signals with third brake light and emergency flashers.
No pics, but I have a dandy Chromium roll of duct tape setting on the bench seat. It is actually a roll of aluminum HVAC tape.
Insomniac
Insomniac
Earlier this week, I installed a front anti-roll bar (usually, incorrectly called a sway bar). Took it out for a ride today; BIG difference in handling on the corners. Worth it!
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Other than safety items, lowering the ride height.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
I am more of a purest, so my trucks don't have too many non-stock items. One exception is an antifreeze "puke can" made from period correct vintage/technology items, down to the 1925 soda bottle. Keeps the truck from marking her spot in inappropriate places.
Lots more pictures
Gord, what anti-roll bar did you go with. Original or ???
RonR
1970 340 Duster
1964 CJ5
GM called it a "ride stabilizer" on the Advance-Design trucks on which it was standard equipment.
Radial tires
3.55 rear gear
Turn signals
Seat belts
12 v Alternator
PCV
Disk bakes
Door latch ( bear claw)
Insomniac
Insomniac
I used the CPP kit. Part #CP179. It's a 1 1/8" bar which I believe is heavier (stiffer) than the one from the factory. I posted about my experience with the kit in the existing thread:
https://www.stovebolt.com/ubbthreads/ubbthreads.php/topics/1113395/sway-bar-sugestions.html
Gord 🇨🇦
Backup lights activated by SM420 shifter.
Cup holder
6 to 12v conversion
blah, blah, blah
Craig
T-5.
Limited slip, 6 lug rear end.
Skinny radial tires.
Moparguy, how well does the T-5 work in your 3/4-ton truck?
Professional Novice
For my 53 3600, Radial tires (Ford 8 lug rims). 12 volt everything, 1 ton tie rod (modern ends and its a bolt on). 4:11 gears, reman springs, 235 ci motor with dual exhaust. 390 cfm Holley.
On my 46 half ton: factory sway bar, dropped I beam, modern tube shocks, radials, all new/rebuilt suspension. 261, T-5 trans, 60s rear end and open drive, 12 volt, vintage air, modern seat,
1946 1/2-Ton Chevy
Frank, it works Great. The frequently heard concern is a T5 isn't nearly as robust as the original SM420. And that's true, however few will work their truck as hard as GM engineered the 3600 and 3800 trucks to work. When these truck worked for a living they pulling loaded grain wagons, loads of logs, stock trailers or hauled loads that likely far exceeded their rated GVWR. I find my T5 with 4.03 1st and .72 5th to be very capable when doing the light to moderate work my truck does frequently. Hauling hay and fire wood are the most frequent work truck jobs.
Best is how it quietens the engine down by dropping revs. The T5 and 4.10s have made the old rig a comfortable 60 (plus) mph highway truck. Before in pure stock trim, 50 was the fast happy speed.
Lots of info here and on the interweb dealing with how-to info for the conversion.
RonR
RonR
1970 340 Duster
1964 CJ5
Awesome Grandpa
Awesome Grandpa
Shell and removable carpet kit / bench seat in the back with a back truck cab window slider.
shell
Load'em up lets all go to the drive-in! nanner
Awesome Grandpa
Awesome Grandpa
That's exactly what we did with the kids!
That's cool. Nice ride.
Thanks RonR.
Very cool ride darthintel.
Professional Novice
My favorite non-stock mod will be the Olds 350 Rocket in my 1960 short fleetside.
[quote=Wally / Montana]It's gotta be this drip catcher.
Now that is nice. I need one for my 350 trans.
1949 5 Window 3100
Follow in the DITY
Veteran of the USAF
My Website
