1 members (Hotrod Lincoln),
104
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Want to swap my oil bath type for an aftermarket flat round paper filter type. My Rochester neck is 2 5/8" diameter and I can get an adapter for a larger neck filter but how does it stay on. The flat round filters all seem to have a bolt thru the center which comes I presume, from the carb. Mine doesn't. There is a bolt on the oil bath filter but that holds the unit together and there is a clamp on the neck to hold it to the carb. Am i missing something here? | | | | | | Anonymous Unregistered | | Anonymous Unregistered | What engine is it one? my 64 230 has a bolt from the carb as well as my 53 216, same with my 60 235...hope it helps. I want go to the aftermarket paper filter aswell eventually. | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | It is a 57 235" with a Rochester single barrel. | | | | | Joined: Jan 2005 Posts: 310 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 310 | I scored a period correct Fram dry element filter on ebay a couple of years ago. It clamps on the throat of the carb just like the oil bath did. You might check into something like that.
-Tim '51 Chevy 3104 w/'56 235, 848 Head, HEI Dizzy, Corvette Cam, Split Manifold and Dual Carter YF's
| | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | You can buy air cleaners with paper filters right out of JC whitney that will fit on your carb. | | | | | Joined: Sep 2002 Posts: 438 Shop Shark | | Shop Shark Joined: Sep 2002 Posts: 438 | Are there any kits that use paper, but keep the oil bath housing or look? My '54 is oil-bath right now and it's just a pain to deal with. I'd like something that looks stock, but doesn't look hot rod. | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | I have seen pictures of a modified oil bath with an opening cut in the front where there is a paper filter exposed. Don't know if it was in one of the recent truck magazines. I am still trying to figure out how to do my conversion, and not having the stud thru the carb to hold a modern type on, I am stumped. | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | The modified oil bath I wrote about in the last post is actually not cut out. Looks like he put a deep paper filter in the bottom and covered the top of the filter with a smaller lid. Hard to tell exactly and it could even be a stock unit from something else. Its in the June 2005 issue of Classic Trucks, page 29. | | |
