3 members (Frank50, frogfarmer, 1 invisible), 254 guests, and 6 robots.
Topics128,077
Posts1,056,012
Members48,433
#132520 06/05/2005 2:44 PM
Want to swap my oil bath type for an aftermarket flat round paper filter type. My Rochester neck is 2 5/8" diameter and I can get an adapter for a larger neck filter but how does it stay on. The flat round filters all seem to have a bolt thru the center which comes I presume, from the carb. Mine doesn't. There is a bolt on the oil bath filter but that holds the unit together and there is a clamp on the neck to hold it to the carb. Am i missing something here?
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
#132521 06/05/2005 11:22 PM
Anonymous
Unregistered
Anonymous
Unregistered
What engine is it one? my 64 230 has a bolt from the carb as well as my 53 216, same with my 60 235...hope it helps. I want go to the aftermarket paper filter aswell eventually.
#132522 06/06/2005 5:03 PM
It is a 57 235" with a Rochester single barrel.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
#132523 06/06/2005 5:26 PM
8
8 Offline
I scored a period correct Fram dry element filter on ebay a couple of years ago. It clamps on the throat of the carb just like the oil bath did. You might check into something like that.
-Tim
'51 Chevy 3104 w/'56 235, 848 Head, HEI Dizzy, Corvette Cam, Split Manifold and Dual Carter YF's
#132524 06/08/2005 3:01 PM
You can buy air cleaners with paper filters right out of JC whitney that will fit on your carb.
#132525 06/08/2005 8:38 PM
Are there any kits that use paper, but keep the oil bath housing or look? My '54 is oil-bath right now and it's just a pain to deal with. I'd like something that looks stock, but doesn't look hot rod.
#132526 06/09/2005 12:47 AM
I have seen pictures of a modified oil bath with an opening cut in the front where there is a paper filter exposed. Don't know if it was in one of the recent truck magazines. I am still trying to figure out how to do my conversion, and not having the stud thru the carb to hold a modern type on, I am stumped.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
#132527 06/15/2005 8:58 PM
The modified oil bath I wrote about in the last post is actually not cut out. Looks like he put a deep paper filter in the bottom and covered the top of the filter with a smaller lid. Hard to tell exactly and it could even be a stock unit from something else. Its in the June 2005 issue of Classic Trucks, page 29.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
