| | | Forums66 Topics128,188 Posts1,057,217 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2002 Posts: 2,895 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,895 | Heya folks.
the engine and exhaust details:
'65 c10 - lwb stepside - 1992 5.7l(350) v8
It has a 600 cfm holley carb (mod. 4160) on it - I forgot to mention this originally (added 09/01/2004)
stock exhaust manifold, exhaust, muffler, exhuast... the pipes are separate - no cross pipe
The issue:
When I crank it up, there is some white smoke coming out the left/driver's side exhuast. It does not seem to be coming out the right/passenger's side.
Any idea what this is a symptom of?
Thanks.
-W | | | | | Joined: Jul 2003 Posts: 31 Junior Member | | Junior Member Joined: Jul 2003 Posts: 31 | Could be a leak in the left side cylinder head gasket. | | | | | Joined: Feb 2002 Posts: 2,895 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,895 | hmn. Anyway to test/check something to find out if that is what it is?
-W | | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | Run a compression test. Does the smoke start immediately of after it warms up a bit? If it is immediate, bad ring(s), valve guide, compression test will find the ring(s). If after it warms up, water in the combustion chamber, compression test won't find it unless it's the head gasket, that's the good news. Larry 68 C20 327/465 daily driver 63 C20 292/420 Camper truck 65 C10 ? /powerglide Custom Cab AC,PB,PS,$flashe 70 C10 250/3spd org/Gauge dash,Wood bed,4Sale$1300
I don't own a vehicle that isn't old enough to drink. | | | | | Joined: Jan 2001 Posts: 662 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 662 | If it's only when cold, it's the heat riser doing its job. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Pull the spark plugs on the left bank & let it sit over night. A pressure tester on the cooling system would help. Crank the engine over & watch for water comeing out the spark plug holes. If there is you have aleaking head gasket or a cracked head. Usually a can of bar,s leak in the cooling system will fix it for a while.  They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | It may just be a carboned up injector not spraying a good pattern or it could be carbon on the back of the intake valves. If it runs relatively smooth, add some injector cleaner additive to the gas tank and drive it enough to heat everything up. It will take a while if your truck does alot of short trips or stop and go driving. Just a thought, Scott | | | | | Joined: Dec 2003 Posts: 510 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 510 | Originally posted by chuckthetruck: If it's only when cold, it's the heat riser doing its job. I agree. If it's a small amount of smoke (steam)and goes away after it warms up, I wouldn't give it a second thought. If it's a huge cloud and it continues after it's warmed up, then I'd start looking for ways that coolant is gettin into one or more cylinders on that side. | | | | | Joined: Feb 2002 Posts: 2,895 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,895 | the '92 engine has a 600 cfm holley carb. (mod. 4160) on it... Well, I have no had to add any coolant in 6 months? or more, since I had to keep adjusting the flex hose since I could not get it to seat just right. So, it isn't using/losing coolant/water. Well, I thought I'd check with you guys. Especially since I need to yank off the intake manifold to fix that oil leak, as mentioned in another post in here - I figured I'd check to see if there is anythign else I need to check/change while I have things taken apart. Thanks. -W | | |
