Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
4 members (cmayna, 2-Ton, 2 invisible), 47 guests, and 3 robots.
Topics128,009
Posts1,055,292
Members48,419
#130607 06/16/2004 5:07 PM
I have a recently rebuilt Chevy 350 SB with an Edelbrock 650 CFM 4 bbl carb and a Crane cam with 260 duration, Carter mechanical fuel pump (for 4 bbl). I have a 350 Turbo auto transmission. I am at the stage where I can drive my truck, but I get poor engine performance on acceleration. In the driveway under no engine load, I can get smooth acceleration from idle to WOT. However, when I am on the road and I stomp the pedal (not that I plan to do that a lot) the engine bogs down and I get no power. However, when I slowly accelerate the engine seems to ramp up to higher RPMs. I am at 10 degrees BTDC on my timing (since I do have a slightly higher performance cam).
What do you think the problem is? I do have a new distributor, wires, etc.
#130608 06/16/2004 7:08 PM
Is the advance working, I throw the timing light on it and see if it advances as RPM goes up.
#130609 06/17/2004 12:58 AM
Sounds like little secondaries action. Maybe a weak accelerator pump. I don't know that much about them carbs, just an educated guess on my part,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#130610 06/29/2004 9:25 PM
Apprentice
Apprentice
1 Offline
Hi,
It might be your rear gears, I have city gears that makes it accelerate fast but slow highway. You might take a look at that. Hope I helped
#130611 06/29/2004 9:51 PM
Is there a TV cable and the proper bracket hook up to the transmission?
52pu
"Drugs are money, money is power, power is security." - Kent Heiner
Nedrow population 2212
Carbon footprint family of 2/11 tonnes of CO2/yr
#130612 06/29/2004 10:19 PM
Did you check all your vacume hoses?
Oops. Never mind -- I just saw you said it idles fine.
~~ Alan Horvath
1954 Chevy Pickup
Singing his praises in the
Passing Lane
#130613 06/30/2004 2:31 PM
Sounds to me that your carburetor is "loading up"(too much gas under acceleration...I had this problem with a Holley 600)... that is unusual for an Edelbrock carb which tends to be very smooth. Check/reset your floats...should fix the problem.
Steve G.
1942 Chevrolet 1/2-Ton Pickup Truck
#130614 06/30/2004 2:52 PM
We run 650's on a dodge, and race car, my 59 has a 750. Sounds and act like accelerator pump, but also moving throttle slow to fast easy, could very well be filter. popcorn The Truth is Out There ( Your mechanical fuel pump should read 7 to 15 psi)
