1 members (baldeagle),
62
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2001 Posts: 61 Member | | Member Joined: May 2001 Posts: 61 | I have a recently rebuilt Chevy 350 SB with an Edelbrock 650 CFM 4 bbl carb and a Crane cam with 260 duration, Carter mechanical fuel pump (for 4 bbl). I have a 350 Turbo auto transmission. I am at the stage where I can drive my truck, but I get poor engine performance on acceleration. In the driveway under no engine load, I can get smooth acceleration from idle to WOT. However, when I am on the road and I stomp the pedal (not that I plan to do that a lot) the engine bogs down and I get no power. However, when I slowly accelerate the engine seems to ramp up to higher RPMs. I am at 10 degrees BTDC on my timing (since I do have a slightly higher performance cam).
What do you think the problem is? I do have a new distributor, wires, etc. | | | | | Joined: Jul 2006 Posts: 232 New Guy | | New Guy Joined: Jul 2006 Posts: 232 | Is the advance working, I throw the timing light on it and see if it advances as RPM goes up. | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Sounds like little secondaries action. Maybe a weak accelerator pump. I don't know that much about them carbs, just an educated guess on my part, Scott | | | | | Joined: Jun 2004 Posts: 12 Apprentice | | Apprentice Joined: Jun 2004 Posts: 12 | Hi, It might be your rear gears, I have city gears that makes it accelerate fast but slow highway. You might take a look at that. Hope I helped | | | | | Joined: Dec 2000 Posts: 506 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 506 | Is there a TV cable and the proper bracket hook up to the transmission?
52pu
"Drugs are money, money is power, power is security." - Kent Heiner Nedrow population 2212 Carbon footprint family of 2/11 tonnes of CO2/yr
| | | | | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | Did you check all your vacume hoses?
Oops. Never mind -- I just saw you said it idles fine.
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | | | | Joined: Feb 2000 Posts: 364 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 364 | Sounds to me that your carburetor is "loading up"(too much gas under acceleration...I had this problem with a Holley 600)... that is unusual for an Edelbrock carb which tends to be very smooth. Check/reset your floats...should fix the problem. | | | | | Joined: Jan 2003 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2003 Posts: 687 | We run 650's on a dodge, and race car, my 59 has a 750. Sounds and act like accelerator pump, but also moving throttle slow to fast easy, could very well be filter. popcorn The Truth is Out There ( Your mechanical fuel pump should read 7 to 15 psi) | | |
