| | | Forums66 Topics128,139 Posts1,056,454 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2007 Posts: 69 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 69 | Has any one tried fiberglass rear fenders. Fitment problems?? Haven't bought any, just wondering if they're worth the money. | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | I just bought a set from a guy on ebay for my 1950 3/4 ton. All I can say is wow! These things fit perfect and they look great. I paid 275 for the set and 100 to ship them to Salt Lake from TN. These are the best purchase I have made for my truck yet. My old fenders were cracked and dented to the point they weren't worth bothering with and all the steels I looked at were either a fortune or the same condition. If you want the guys e-mail let me know he is really a good guy and makes all his own parts. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I've ran R&R Fiberglass fenders for years. They are out of Tenn. I like them and they hold up well. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Be careful when tightening down the fender bolts. Too much torque and you will put a crack in that glass fender.
~Jim
| | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | I have a set of new glass rear fenders to install on 52 ...would it be a good idea to use rubber washers under the bolts and self locking nuts ??...to ease the chance of cracking the new glass ??. any tips/tricks will be appreciated. Thanks ! Tim | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Tim, I didn't use rubber washers but I did use a little bigger flat washer. I have had no problems but thats not to say rubber washers would not be a good idea. I've had the 37 well past 100 on several ocassions and sure the fiberglass "shook" a little but no problems anywhere.....I even left off a couple braces so I would not drill through the fiberglass.....however I have some special type brace i want to put on them......someday!! | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | The tips that the guy provided me on purchase was to make sure I cleaned them well before painting to remove the mold release agent. The second recommendation was a good undercoating to prevent stone damage. | | |
