| | | Forums66 Topics128,180 Posts1,057,158 Members48,464 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 24 Junior Member | | Junior Member Joined: Dec 2006 Posts: 24 | ok guys so im having the chassis sandblasted and i just got a quart of POR 15 and a quart of chassis black coat also from POR 15. I know that the POR 15 can be applied by brush but what about the chassis black coat. could i also apply it with a brush or should i invest in a spray gun. ive checked on previous posts but if any of you guys have any comments, suggestions please let me know.
thanks in advance | | | | | Joined: Jul 2006 Posts: 243 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 243 | im no wher close to doing my frame, but i plan on brushing it on, was told its super nasty stuff when sprayed.... | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | definitely brush on the Por 15 but I am not sure about the chassis black. | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | Make sure ya have PLENTY OF VENTILATION !.... | | | | | Joined: Jun 2005 Posts: 191 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 191 | Chassis Black brushes on just like POR15. It levels off smooth. | | | | | Joined: Jan 2002 Posts: 866 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 866 | I brushed mine on, came out real smooth. | | | | | Joined: Dec 2006 Posts: 24 Junior Member | | Junior Member Joined: Dec 2006 Posts: 24 | for you guys who brushed the chassis black on what size paint brush did you use and what worked best for you did you use a one inch brush or bigger. any pics ??? | | | | | Joined: May 2005 Posts: 22 Junior Member | | Junior Member Joined: May 2005 Posts: 22 | Anchondo, where in el paso are you??? I'm in the North East. I have a 56 3100 i'm working on. Maybe we can help each other out. I used a 1 inch brush for the frame. | | | | | Joined: Aug 2006 Posts: 29 New Guy | | New Guy Joined: Aug 2006 Posts: 29 | I used a foam roller for the majority of my frame. I also used a brush, but used cheap for both because the brush and roller are toast after use. I thought the finish was better with the roller. | | | | | Joined: Jul 2005 Posts: 640 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 640 | I seem to recall that POR-15 needs something over it. I mean that the regular POR-15 can't be the finish coat, because it degrades in sunlight. Is that still true? | | | | | Joined: Dec 2005 Posts: 257 Shop Shark | | Shop Shark Joined: Dec 2005 Posts: 257 | I used POR-15 on my last truck and Zero Rust on my present truck. I used the cheap foam brushes for both because as mentioned before, the brushes are toast after one use. I had a couple different sizes on hand for those tough to reach spots and the wider (1 or 1-1/2") brushes for those wide-open-road-cruising spots, like the outside of the frame.
The directions call for two coats of POR-15/ZR and then a top coat. I only put the top coat (spray can gloss black) on places that would see the light of day. When I sold the other truck 4 years later, it still looked as good as the day I finished it.
After completing my present truck frame, I found that the POR-15 smoothed out better than the ZR after being brushed on. The benefit of ZR is it comes in spray cans. On the next truck (don't tell my wife there's going to be another one), I'll use ZR again but only in the spray can. | | | | | Joined: Mar 2001 Posts: 629 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 629 | i used zero rust and could not be happier. check out thephotos on my web page. I used the spray cans.
Tim Sheridan 1947 First Series Chevy 1/2-Ton"Liberty Series" - "Art Deco" - Whatever you'd like to call it. In the Gallery | | | | | Joined: Aug 2005 Posts: 442 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 442 | Just used Zero Rust on the insides of my '50 back fenders, looks great, sprayed it on with an HVLP gun
Mike | | |
