3 members (Wheelie, Peggy M, Tom McGrath), 85 guests, and 2 robots.
Topics128,195
Posts1,057,374
Members48,469
#1254253 02/09/2018 12:13 AM
Moderated
Moderated
Wondering what the best way to secure the cowl vent gasket on a 1954 Chevy 3100? Silicone???
Y
Y Offline
A rubber seal is sold. If you're trying to permanently secure it they sell a weld on patch panel.
"I always win." Working mainly alone I do not let my trucks win a war. Maybe a battle here and there but never the war.
Robert
55.1 GMC 450 COE
51ish GMC Suburban
Not sure about a 54 but some earlier years you will find vendors with "original Cork" and also solid rubber.
I used a solid rubber on my 37 for a while but it would never "seat" or "seal" tight on the hard rubber and I usually had a leak.
I changed to the cork seal and used 3m adhesive and have not had a problem in years! Just my experience.
3-M weatherstrip adhesive. Make sure you follow the directions.
on the tube
I did something different altogether.
I bought the soft foam style cowl seal and glued it to the bottom of the vent door, just inside the lip instead of the cowl. The lip on the cowl engages the foam seal more securely than how the bottom edge of the vent door engages the seal. I did have to cut the foam seal and glue the ends back together so it will fit inside of the lip under the vent door. That foam is easy enough to glue with weatherstrip adhesive. No leaks, even when sprayed with hose.
So is recommendation to go on the vent side rather than the cab side? I bought both seals for my 47’s vents and want to locate them correctly.
Just here for the free beer.
1953 1-Ton Dump Truck
1954 Teenage Hot Rod
I seal that rubber seal on the body/cab side of the seal.
Chevy Duty/Classic Parts (many years ago) and Jim Carter (many years ago) and Steele (more recently installed).
No leaks over many year and many storms (if I close the scoop/vent).
tclederman #1269635 06/20/2018 11:41 AM
I was thinking the same as they aren’t out “in the wind”
Dont use silicone on the truck, it will return a favor if you ever decide to do any paint work in the future.
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
e
I have had so much bad luck with the extremely hard rubber seals from the vendors, that I went outside the box to solve the problem. It may not pass a 100 point Originality Test, But you would be hard pressed to notice the difference in appearance. You will definitely notice a dry floor inside the cab after a downfall.
