1 members (Brian Moore),
95
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2004 Posts: 5,069 Authorized Pest | | Authorized Pest Joined: Apr 2004 Posts: 5,069 | Another Tech Tip from Bartamos. He wrote a great tip on making solid side windows for a Suburban. A reference was the "string method," which many people have heard of. But same may not. So Ken worked up this side bar to go with that tip. Thought I'd add it here too in case anyone isn't familiar with this. Thanks Ken! Peggy M
~ Peggy M 1949 Chevrolet 3804"Charlie" - The Stovebolt FlagshipIn the Gallery"We make a living by what we get; we make a life by what we give." -- Winston Churchill | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Great tech-tip thanks for sharing.
Just to clarify a point. People should note,the "string method" applies to 'S' section rubber seals and not to the 'H' section lock strip style rubbers commonly used in the rear of some vehicles. Just in case there's any confusion.
1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Apr 2009 Posts: 252 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 252 | | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Used this on my front window install and it made it a really simple job, it works great. | | | | | Joined: Nov 2010 Posts: 17 New Guy | | New Guy Joined: Nov 2010 Posts: 17 | I used GoJo for a lube with this method once with good results. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | For a window-seal/string lubricant that will not harm rubber or contaminate painting, you might want to use an unscented, non-abrasive, non-silicone, non oil-based, water-soluble lubricant, such as a "personal lubricant" (lubricating jelly) that can be bought in any drug store as an inexpensive, generic-label product.
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Personally I've found some 'lubricants' too slick,so I prefer to use good old water based glass cleaner. The only downside is it can evaporate a little quickly,especially if it's warm. (not usually too much of a problem here!) 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | X2 on the Windex. I've used it a lot. Sometimes though I think it has a lot to do with the rubber to...anyway, the windex works | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | I like Tim used the Jelly and liked that I could apply it with as small brush and it wipes up easily. I also used some of that 3M (blue)gentle type masking tape to hold the gaskets in place, the stuff grips but does not pull paint when you remove it. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Just to be clear. The tip was possibly edited a little. The ends of the string/rope should be at the BOTTOM. Start pulling it out from the BOTTOM. This lets the glass settle downwards using it's own weight and lots of lube/soap. It needs to settle downward in order to be able fit in at the top as the rope is fully removed. The "training" comment is referring to taping the rubber onto the window for a few hot days/weeks to allow it to retrain from a rolled up configuration to a around the windshield shape. (I think this "training" is a very important step). This pre forming of the rubber is covered in the adjoining tip about side windows. If you have the delux stainless trim, put on top, bottom then sides, then corners after rubber is on window and before pulling string. The trim is pinched by the install and held in place. Check it while installing windshield, gently rubber hammer it back in if it starts to come out. Add clips after install. You may find that installing clips before pulling will work for you. Even the pro's have different methods of doing all this.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | .....The ends of the string/rope should be at the BOTTOM. ..... I would say that the string needs to start where you first insert the "window frame" into the rubber. In the early 1960 models, the windshield has to go into the TOP first because of the overhead eyebrow over the windshield. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | ... I would say that the string needs to start where you first insert the "window frame" into the rubber. In the early 1960 models, the windshield has to go into the TOP first because of the overhead eyebrow over the windshield. wrong according to the factory .... the eyebrow [same as 55-59 trucks] has no effect, the glass is placed against the opening all the way around before the string work starts, and the rubber is pulled on bottom first Bill | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | wrong according to the factory .... the eyebrow [same as 55-59 trucks] has no effect, ..... Bill [/quote] I beg to differ. The eyebrows are not the same at all on the 60's models. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | UPDATE: After researching 55-59 windshield install, reading manuals and tech sections, the common wisdom/advice is to place the windshield down on the bottom pinch weld and start pulling the rope from the bottom and swing the top in. After installing two windshields and trying many times on both of them, I was only able to do the job by pulling the rope from the TOP. Worked the first time, both windshields, after trying the bottom pull, many times. I hereby change my tip advice to: "What worked for me is start pulling rope at top." Pulling to the left and right evenly, using soap and water. Both windshields had the chrome strip. On the second windshield I changed to a non chrome strip rubber. I will never do another chrome strip install, I will always do a non chrome. It adds too much more trouble to a non pro like me to deal with. There are extreme tolerances on opening and glass. If you get a small opening and a big glass, it's a little more work. I have only found a few shops that have experience, they either want to sell you the glass and install for $700/up or install for $300/up and if they break it YOU buy another. There is NO U.S. glass for these trucks. It's all "off shore" as they say.(Chinese)
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: May 2010 Posts: 22 'Bolter | | 'Bolter Joined: May 2010 Posts: 22 | Is it better to install the windshield, rubber AND metal frame all as one unit? (I have a '51 3100)
Haasman | | | | | Joined: Oct 2016 Posts: 916 'Bolter | | 'Bolter Joined: Oct 2016 Posts: 916 | I have only installed one from windshield (a '50 3600), after two tries.
My center rubber strip is slightly off-center at the top (the windshield center rubber is probably 1/4" towards the driver side, at the very top). Pulling on the glass laterally with a heavy duty suction cup and my hand on the other side of the glass has moved it slightly, but not completely. Has anyone else had trouble getting het windshield rubber to align in the center perfectly, or do most just allow it to lean slightly? Or is it just me??
~ Dave 1950 Chevrolet 3600 3/4-ton with 261 engine & T5 Transmission | | | | | Joined: Oct 2005 Posts: 4,249 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,249 | | | | | | Joined: Mar 2010 Posts: 10,271 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,271 | No one likes a show off, Mark.  Nice work though!
