10 members (BarryP, mick53, Bill Hanlon, rfs56trk, Nick in Manitou, UtahYork, NorCal52Suburban, Hanks custodian, Donf, 1 invisible), 140 guests, and 3 robots.
Topics128,136
Posts1,056,745
Members48,454
it supposded to be better than por 15 or so i was told im looking for the correct shade of semi gloss black to paint under my hood and firewall and i only want to do it once anyone...
anyone?
The product in question is a direct knock off of Zero Rust, if that tells you anything. ;^) If you'd like to see a heads up comparison between Zero Rust and POR go to http://www.autobodystore.com/images/boattest.jpg the test was on the motor mounts on a saltwater fishing boat and the pictures were taken after 16 months.
looks like good stuff thanks
used some today wow its great stuff highly recomend
Junior Member
Junior Member
oldno3fan-
"used some today wow its great stuff highly recomend"
Are you referring to the SEM?
I recently bought a spray can of SEM to test sheen for chassis and black parts. Also have been comparing ZR and Rust-Lok [a PETIT marine below waterline primer that I have not seen anyone mention (guessing like POR15 b/c of U/V exposure instability, etc ?)].
If SEM is truly comparable to ZR then I would like thoughts or cyber shoulder shrugs.
Thanks!
I have some I bought to do the frame etc on the burb,hope to use it this weekend if all goes well,,brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
Haven't seen this "brand" around my neck of the woods. Where do you get it?
Junior Member
Junior Member
I found it at Finishmaster. Not sure how widespread tehy are...distributor of automotive and industrial paint, etc.
Here is the link to the product:
http://www.sem.ws/product.php?product_id=154
The advantage for me is that it is available down the road.
