| | | Forums66 Topics128,154 Posts1,056,838 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2005 Posts: 112 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2005 Posts: 112 | it supposded to be better than por 15 or so i was told im looking for the correct shade of semi gloss black to paint under my hood and firewall and i only want to do it once anyone... | | | | | Joined: Feb 2005 Posts: 112 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2005 Posts: 112 | | | | | | Joined: Feb 2001 Posts: 164 Shop Shark | | Shop Shark Joined: Feb 2001 Posts: 164 | The product in question is a direct knock off of Zero Rust, if that tells you anything. ;^) If you'd like to see a heads up comparison between Zero Rust and POR go to http://www.autobodystore.com/images/boattest.jpg the test was on the motor mounts on a saltwater fishing boat and the pictures were taken after 16 months. | | | | | Joined: Feb 2005 Posts: 112 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2005 Posts: 112 | looks like good stuff thanks | | | | | Joined: Feb 2005 Posts: 112 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2005 Posts: 112 | used some today wow its great stuff highly recomend | | | | | Joined: May 2006 Posts: 11 Junior Member | | Junior Member Joined: May 2006 Posts: 11 | oldno3fan-
"used some today wow its great stuff highly recomend" Are you referring to the SEM?
I recently bought a spray can of SEM to test sheen for chassis and black parts. Also have been comparing ZR and Rust-Lok [a PETIT marine below waterline primer that I have not seen anyone mention (guessing like POR15 b/c of U/V exposure instability, etc ?)].
If SEM is truly comparable to ZR then I would like thoughts or cyber shoulder shrugs.
Thanks! | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | I have some I bought to do the frame etc on the burb,hope to use it this weekend if all goes well,,brian | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Haven't seen this "brand" around my neck of the woods. Where do you get it? | | | | | Joined: May 2006 Posts: 11 Junior Member | | Junior Member Joined: May 2006 Posts: 11 | I found it at Finishmaster. Not sure how widespread tehy are...distributor of automotive and industrial paint, etc. Here is the link to the product: http://www.sem.ws/product.php?product_id=154 The advantage for me is that it is available down the road. | | |
