0 members (),
64
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | I discovered on my 53 1/2 ton that the tops of the new inside cowl panels that were installed cover the guide holes for the outside mirrors. I forgot to mention their purpose before and now I will have to determine exactly where to place the mirrors and use sheet metal screws. Would a paper template from an existing truck (with mirrors) be the only way to do this? The other option would be to use the peep mirrors, but I like the original style. Steve | | | | | Joined: Mar 2010 Posts: 10,270 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,270 | A slick trick is to use an automatic center punch from the inside of the cab. There is a reinforcement bracket on the inside which has the holes for the mirror. Just place the pointy end of the automatic center punch in the middle of each hole and push until it unloads its force and makes a dent which you should be able to see on the outside. Carl
| | | | | Joined: Aug 2016 Posts: 146 Shop Shark | | Shop Shark Joined: Aug 2016 Posts: 146 | | | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | Thanks Carl, but maybe I was not very clear on my post. I understand what you said about the reinforcement bracket, but it was covered when the new inside cowl panels were installed. They should have been cut off a few inches at the top. Steve | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ....maybe a stupid question but can you cut some of the top of the panel off with some tin snips? | | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | Not really stupid question. As a matter of fact, that's a good idea. Getting in there might be a challenge though. Steve | | |
