| | | Forums66 Topics128,139 Posts1,056,758 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2011 Posts: 11 New Guy | | New Guy Joined: Oct 2011 Posts: 11 | 49'chevy one ton. this truck has a 9ft box. this box is factory. the frame has 1ft extensions bolted on. How rare is this? or is this the standard box for a 1ton
| | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | The box is fairly rare, but that doesn't necessarily mean valuable. As for the bolt on extensions, I've never seen them or heard about them. I wonder if somebody did their own modification of a 3/4 ton to use a 1 ton bed. | | | | | Joined: Nov 1995 Posts: 5,730 24601 | | 24601 Joined: Nov 1995 Posts: 5,730 | I have an unrestored '49 1-ton pickup and it does not have bolted- on frame extensions. I'm inclined to agree with FGT. What does the VIN tell you when you use the VIN decoder (Look in the Tech Tips).
As for rarity, there aren't as many around as the half-tons, but they're not exactly "rare" like Cameos or the late '20's roadster pickups might be. About the second or third show I took mine to, another '49 3800 (even red with black fenders, too) parked right next to me. Hmmm.
Regards, John
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Apr 2011 Posts: 224 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 224 | Interesting to note, I have a '51 1 Ton Panel--unrestored. It has the "riveted" extensions. It also has front and rear shocks, but the VIN plate says it's a 1 ton. Maybe it was a factory thing; quick solution by using on-site 3/4 ton frames?
As for the box, they are scarce. The 9 foot box is the standard box for the 137" wheelbase. And as with truck values, they are worth what you're willing to sell it for. Condition is key, a good condition box will save you the headache of finding an alternate truck bed.
Dave Baird 1951 Chevy 3803Foot starters are for Stovebolters and people who need a kick in the ...
| | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | My '49 3800 pickup has frame extensions. I can't remember if they were riveted or welded on. I'll take a closer look and post a photo when I get a chance. | | | | | Joined: Apr 2005 Posts: 381 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 381 | My '48 3800 1 ton pick up (9 ft Box) had the rear frame extensions riveted on. Factory set up. I made this truck into a rack body 20 years ago , because the bed sides were too rotted out. Finding good 9ft bed sides is quite a challenge. 1 ton frames differ from 3/4 ton frames. There is no hump in the frame over the rear axle on the 1 ton frame. | | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | My 1-Ton also has the riveted extension on the rear of the frame. | | | | | Joined: Apr 2010 Posts: 18 New Guy | | New Guy Joined: Apr 2010 Posts: 18 | My 49 also has the extensions rivited on. Pic in photobook. | | | | | Joined: Apr 2009 Posts: 94 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2009 Posts: 94 | My 1949 Chevy 1 ton also has a riveted on 1ft frame extension, but i beleive mine was a factory cab and chassis model. Heres a picture of the rear frame i have: rear frame | | | | | Joined: Apr 2011 Posts: 224 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 224 | I think we clearly identified that frame extensions from the factory exist, but does anyone know why? I mean I have a pickup without and a panel with? It's got me thinking!
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I know this is another old thread but it has some good discussions and questions.
I have a 1 ton 52 Chevy pickup without frame extensions and a 51 GMC flat bed with them, though they've been torched some to mount a hitch.
Trying to swap the pickup bed to the GMC and want to know more about these extensions.
Does anyone have detailed drawings of the extensions in case I need to remake mine?
Any answers as to which model 1 tons have them and why?
Grigg | | | | | Joined: Apr 2000 Posts: 199 'Bolter | | 'Bolter Joined: Apr 2000 Posts: 199 | I'd never heard of these. I have 2 full trucks, a 47 and a 51. Also a 3800 49 panel. And a 50 ish 3800 frame. Tell me what I'm looking for and I will compare. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I wasn't able to get any pictures today but should tomorrow.
Roughly measuring (and from memory) from the rear edge of the rear spring hanger one truck has 9.5" of frame after that, and the other has about 21".
The short one then has a piece of lighter weight frame slipped inside of the main frame to add to the length.
I will need to replace my torched frame extensions on the GMC to use the pickup bed. | | | | | Joined: Dec 2011 Posts: 241 'Bolter | | 'Bolter Joined: Dec 2011 Posts: 241 | While searching for some info on a one ton bed and box assembly I came across this post. I have welded tails onto my frame since the originals had been cut off for a dump bed. I have left them long to cut off later once I start to assemble the bed and box. I was surprised to find the assembly manual I have has no drawings regarding the bed or box. I am now trying to fix up the cross sills ready for blasting and priming. Is there no drawings out there showing this assembly? Extensions http://s1142.photobucket.com/user/52_Ton/media/IMG_2537.jpg.html?sort=3&o=0Mark | | | | | Joined: Dec 2006 Posts: 321 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 321 | I dont know if this will help or not...Howard Knapp was a flat bed dump truck in its former life... I had to add these to the back frame rails to get the 9 foot pickup box to fit...2x4 rectangular steel tubing left over from a former project... rear view good luck... MikeC
1951 Chevy 3800 1-TonHoward KnappIn the Stovebolt Gallery1948 Chevy 1-Ton (sold Nov 2017)1953 Chevy 1-Ton (sold 10/1/2016) | | |
