9 members (TexasA&M48Truck, walter74, 32Fordpuchoptop, JW51, Hotrod Lincoln, baldeagle, 51sub, NJC, 1 invisible),
42
Mod | | | Forums66 Topics128,005 Posts1,055,255 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2013 Posts: 363 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 363 | can anyone tell me what these lines hook up to. i have a 52 chevy 1ton 261 motor thanks [URL=http://s1296.photobucket.com/user/cuz2424/media/Chevy/IMAG0363_zpsrusdvewa.jpg.html]chevy[/url] [URL=http://s1296.photobucket.com/user/cuz2424/media/Chevy/IMAG0364_zpshf3qw3uq.jpg.html]chevy[/url] | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I'm not sure which lines your talking about but it appears there is two lines that go to a bypass oil filter, There should be a vacuum line going from windshield wiper motor to the connection below the carb that is screwed into the exhaust manifold, I didn't get very clear pictures but there is probably a vacuum line going to the distributor. I see the temp line is hooked up.
...maybe I don't see all the picture? Can you take a picture with pointers to lines in question?
Hang tight jimbo, someone will add to it that knows more than me. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | 363 - coolant temperature sender into the head? 364 - by-pass oil filter line (just a guess - the end connections are not viewable) | | | | | Joined: Mar 2010 Posts: 10,270 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,270 | The first pic with the elbow pointing upward is probably for PCV and goes to an air cleaner which had a corresponding nipple. My best guess.
| | | | | Joined: Jul 2013 Posts: 363 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 363 | first pic is on the valve cover the second is by the block. i don't know where they go | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | 52Carl is right on the first pic. Second pic shows where the vacuum wiper hose attaches.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jul 2013 Posts: 363 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 363 | | | |
