Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
3 members (Hotrod Lincoln, baldeagle, Tony292), 30 guests, and 2 robots.
Topics128,003
Posts1,055,244
Members48,418
#1166999 05/26/2016 1:06 AM
can anyone tell me what these lines hook up to. i have a 52 chevy 1ton 261 motor thanks [URL=http://s1296.photobucket.com/user/cuz2424/media/Chevy/IMAG0363_zpsrusdvewa.jpg.html]chevy[/url]
[URL=http://s1296.photobucket.com/user/cuz2424/media/Chevy/IMAG0364_zpshf3qw3uq.jpg.html]chevy[/url]
jimbo 24 #1167003 05/26/2016 1:27 AM
I'm not sure which lines your talking about but it appears there is two lines that go to a bypass oil filter, There should be a vacuum line going from windshield wiper motor to the connection below the carb that is screwed into the exhaust manifold, I didn't get very clear pictures but there is probably a vacuum line going to the distributor. I see the temp line is hooked up.
...maybe I don't see all the picture? Can you take a picture with pointers to lines in question?
Hang tight jimbo, someone will add to it that knows more than me.
jimbo 24 #1167011 05/26/2016 2:06 AM
363 - coolant temperature sender into the head?
364 - by-pass oil filter line (just a guess - the end connections are not viewable)
jimbo 24 #1167013 05/26/2016 2:19 AM
The first pic with the elbow pointing upward is probably for PCV and goes to an air cleaner which had a corresponding nipple. My best guess.
jimbo 24 #1167024 05/26/2016 5:06 AM
first pic is on the valve cover the second is by the block. i don't know where they go
jimbo 24 #1167028 05/26/2016 6:21 AM
52Carl is right on the first pic.
Second pic shows where the vacuum wiper hose attaches.
My Blog
jimbo 24 #1167432 05/30/2016 2:10 AM
thanks guys
