8 members (Stewart2, Peggy M, Steelonsteel, moparguy, Millenimech, 3 invisible), 130 guests, and 6 robots.
Topics128,077
Posts1,056,032
Members48,433
HI fellow stovebolters
I am nearing the end of a 13 month "quick" rebuild of Howard Knapp...I bought a complete exhaust system from Chev of the 40's and I cant for the life of me figure out how the muffler strap and the muffler bracket is supposed to work together...I have been on this website searching for photo and the internet also....it is a funky looking about 1" wide and about a 16 gauge in thickness with a very distinct curl on one and a "T" handle threaded rod with a nut on it...
I am sure someone on here has hung these things...my manual is very vague as to how it is supposed to work together...
Any photos would be a wonderful thing...
Thanks in advance
MikeC
1951 Chevy 3800 1-Ton
Howard Knapp
Mike, I know I've seen pictures post here before so hang tight someone will show up.
On my 52 panel the bracket attaches overhead. One end of the strap fastens on one side of the bracket and then you wrap it under and around the muffler and fasten it in the other side of the bracket and tighten it with the T handle.....but your 1 ton may be different from my 1/2 panel??
The pro's will be along shortly..... probably Next Year!!
Denny G
Sandwich, IL
' Offline
1954 3600
Now cruising in
The Passing Lane
MikeC,
Here is the area of the diagram posted by '54 3600 that shows the "strap". Each end of the strap is bent to fit the diameter of the muffler. One end of the strap go through a slot in the hanger/bracket and the other end of the strap goes through eye/opening in the threaded bolt that tightens the strap against the muffler.
It is hard to explain, but the diagram should be a big help (thanks, '54 3600).
Riding in the Passing Lane
It was the same setup on the small & large trucks.
1972 Chevy c10 Cheyenne Super
Thanks guys...I found 2 rivets and a broken bracket on the side rail of the frame rail on the drivers side....from these photos I am seeing looks like all these mount to the cross-member and not the side of the frame rail?? My truck is a 1 ton ...
Just wondering out loud...
I am way closer than I was last night to understanding these parts and how they all fit together...
Awesome awesome awesome help on here...
MikeC
Howard Knapp
