0 members (),
133
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,101 Posts1,056,182 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 321 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 321 | HI fellow stovebolters
I am nearing the end of a 13 month "quick" rebuild of Howard Knapp...I bought a complete exhaust system from Chev of the 40's and I cant for the life of me figure out how the muffler strap and the muffler bracket is supposed to work together...I have been on this website searching for photo and the internet also....it is a funky looking about 1" wide and about a 16 gauge in thickness with a very distinct curl on one and a "T" handle threaded rod with a nut on it...
I am sure someone on here has hung these things...my manual is very vague as to how it is supposed to work together...
Any photos would be a wonderful thing...
Thanks in advance
MikeC 1951 Chevy 3800 1-TonHoward KnappIn the Stovebolt Gallery1948 Chevy 1-Ton (sold Nov 2017)1953 Chevy 1-Ton (sold 10/1/2016) | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Mike, I know I've seen pictures post here before so hang tight someone will show up. On my 52 panel the bracket attaches overhead. One end of the strap fastens on one side of the bracket and then you wrap it under and around the muffler and fasten it in the other side of the bracket and tighten it with the T handle.....but your 1 ton may be different from my 1/2 panel?? The pro's will be along shortly..... probably Next Year!! | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 |
Denny G Sandwich, IL
| | | | | Joined: Jul 2007 Posts: 444 Shop Shark | | Shop Shark Joined: Jul 2007 Posts: 444 |
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | MikeC, Here is the area of the diagram posted by '54 3600 that shows the "strap". Each end of the strap is bent to fit the diameter of the muffler. One end of the strap go through a slot in the hanger/bracket and the other end of the strap goes through eye/opening in the threaded bolt that tightens the strap against the muffler. It is hard to explain, but the diagram should be a big help (thanks, '54 3600). | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | It was the same setup on the small & large trucks. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Dec 2006 Posts: 321 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 321 | Thanks guys...I found 2 rivets and a broken bracket on the side rail of the frame rail on the drivers side....from these photos I am seeing looks like all these mount to the cross-member and not the side of the frame rail?? My truck is a 1 ton ...
Just wondering out loud...
I am way closer than I was last night to understanding these parts and how they all fit together...
Awesome awesome awesome help on here...
MikeC 1951 Chevy 3800 1-TonHoward KnappIn the Stovebolt Gallery1948 Chevy 1-Ton (sold Nov 2017)1953 Chevy 1-Ton (sold 10/1/2016) | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | |
