1 members (UtahYork),
85
Mod | | | Forums66 Topics128,186 Posts1,057,315 Members48,468 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2014 Posts: 136 Shop Shark | | Shop Shark Joined: Oct 2014 Posts: 136 | Where is the battery located on your AD truck?
Is it in the stock, under passenger floor, location...or did you move it somewhere else?
...inquiring minds would like to know. LOL
Thank You Tim
'53 3100 5-window '57 Mercury Monterey 2-Door Sedan Tim H
| | | | | Joined: Jan 2001 Posts: 1,426 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,426 | Original location, under the pass. floor, with 00 cables and master shut off, very handy for doing anything electrical, also an anti-theft item.
~ Cosmo 1949 Chevy Half Ton Rocinante, like Don Quixote, he is awkward, past his prime, and engaged in a task beyond his capacities. "...my good horse Rocinante, mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes "If you come to a fork in the road, take it."...Yogi Berra "Rudeness is the weak man's imitation of strength." ...Eric Hoffer
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | As described by Cosmo, in original location.
| | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | It baffles me why anyone would want to move it. How perfect can you get? Its out of the way. No other MODERN vehicle has this amazing feature. If your jumper cables are not long enough, get longer ones. Meanwhile, it doesnt get any better than where it is! The master cutoff is pretty cool and easier where the battery is!
Thank you and I will be playing all week! | | | | | Joined: Jun 2012 Posts: 1,749 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,749 | After working on a 57 TF truck for the last year or so, I am so glad my battery is out of the way. Stock location is perfect. My 52 had some rust and missing bits. But a little welding and it was good to go. Only other truck battery location I liked was on the 67 chev. Off to the side of the radiator. It never got in the way. The heater, well that is another question. Jump start an AD truck? Roll down the window pull along side and there you go.
Steve H
| | | | | Joined: Aug 2013 Posts: 293 'Bolter | | 'Bolter Joined: Aug 2013 Posts: 293 | Same original location as above, except for the upgraded 00 wire and a master power shut off. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | my 52 is in original place. | | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | No other MODERN vehicle has this amazing feature. I beg to differ, 2005 Buick Le Sabre has the battery under the rear seat. It is a special type of vented battery, it is vented out via hoses through the floor boards. Expensive to replaced. 50 bucks more than a normal battery. There are terminals under the hood to connect to if it needs a jump. At one time in my 54 panel I had both a 12v battery and a 6v battery. The 6v was in the original location and the 12v was mounted on the passenger side fender skirt. On the engine was the original 6v generator and a 12v alternator with a built in regulator, both turned using the same fan belt. I used the 12v battery to power a 12v high wattage sound system. The 6v battery was used for the trucks original electrical system. Both batteries shared the same ground. With engine off, after a couple hours the 12v battery would drain down dead. I would kid everyone that we were stranded. Then I would hop in the truck and start it up with the 6v battery. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | And they tuck my wife's Chrysler Sebring battery under the front fender. First car was a '41 Caddy, which placed it in the same place as the '50, 3600, under the floor on the passenger side.
dg
Denny G Sandwich, IL
| | | | | Joined: Mar 2007 Posts: 4,217 Moderator | | Moderator Joined: Mar 2007 Posts: 4,217 | my 52 is in original place. mine too | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Original with my master cut-off on the seat valance. The only downside to the stock location IMO is maintenance. Out of sight, out of mind. Same with the master cylinder. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | When your battery needs replacing, get a good sealed 6v battery and, after that, battery maintenance becomes another story about the good old days.
| | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | Mine is located under the passenger seat, as original. Thinking of installing an Optima 6V down there. Anyone have picts of that installation or any thoughts?
Ed
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | It goes right in without an adaptations. I use the original style "cover"/hold-down. Place the battery on a diagonal and be sure the posts are not touching the hold-down. To be safe, I also use attery post anti-corrosion "washers" on the posts, after the hold-down has been installed. | | | | | Joined: Mar 2014 Posts: 195 Shop Shark | | Shop Shark Joined: Mar 2014 Posts: 195 | My battery is in the original place under the pass. side floor. Chevrolet 3100 Year: 1951 engine: inline 6 217CI Transmission: Manual 3-Speed. 12Volt. | | | | | Joined: Mar 2014 Posts: 195 Shop Shark | | Shop Shark Joined: Mar 2014 Posts: 195 | BTW, I've always wondered why people would move them under the hood? Doesn't "look" right with that hump on the firewall.. Chevrolet 3100 Year: 1951 engine: inline 6 217CI Transmission: Manual 3-Speed. 12Volt. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | GM moved it there is later years. Probably so that people could see the leaking batteries (and corrosion on the firewall, etc)?
| | | | | Joined: Mar 2003 Posts: 1,132 Shop Shark | | Shop Shark Joined: Mar 2003 Posts: 1,132 | Miss POllys 2000 Bonneville also has that $150 battery under the back seat. Huge PITA. Wonder who thought that up?
Weeds | | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | It really does not bother me that Buick put the battery under the rear seat of the 2005 La Sabre. Because it is the only full size 4 door car that I know of that gets 30 MPG on the highway. And I can fit in it, comfortably. Just don't make'm like that anymore! | | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Original location, out of the heat from the engine bay. Heat is a major cause of battery failure.
Fred 52 3600 69 C-10
| | | | | Joined: Jun 2012 Posts: 1,749 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,749 | Fred T: You have that right! Most folks worry about the cold. And the battery draw is often higher when starting on a cold day, but the killer of batteries is heat. More fail in the summer. It is just less painful to pull and swap when the weather is good. Besides, who wants to reach under the battery to change the #5 and #6 spark plugs? Hate reaching over the fender and under the battery to get to those on my buddy's 57. If you hit something that can get to the battery support, well you might want to change where you are headed. Or at the very least, how you are getting there.
Steve H
| | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 |
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: May 2015 Posts: 10 New Guy | | New Guy Joined: May 2015 Posts: 10 | Mine is under the passenger side floorboard. Have to take 2 screws out of the floor mat strip if you want to jump start it, but, then, what are the chances of there being another 6V vehicle around to jump start it anyhow. Put it in 3rd and start pulling. On the plus side, I suspect the location protects it from the engine heat, making it last longer as well.
It was broke when it came in here, so I'm not responsible
| | | | | Joined: Jun 2008 Posts: 325 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 325 | Mine is under the hood on the passenger side - that is the way the truck came. It really is in the way to get at the last 2 spark plugs. Considering moving it back to where it belongs. | | |
