9 members (TexasJim50, klhansen, Gdads51, J Lucas, Stovebolt48, Hotrod Lincoln, tclederman, GusG, Peggy M), 115 guests, and 2 robots.
Topics128,089
Posts1,056,422
Members48,443
#1096163 04/08/2015 11:19 AM
I have a '61 261 that is developing 40psi running oil pressure. Question is -- is it ok to hook it up to my original '37 dash guage that only goes to 30 psi? Would prefer the dash guage hook up to maintain original look but could live with under dash guage if its going to create problems down the road. Thanks in advance for any thoughts
I have the original 30 psi gauge in my 50 Chevy that has a 54 235 in it. It stays pegged at 30 psi most of the time except at warm idle but my thinking is that I am only worried about too little pressure - not too much for the gauge.
Mike
You can run it as is as Huck suggests. On my 37, with a small block V8, I had the gauge re-calibrated by D&M Restorations which is close by. What ever it reads just double it. When its 15 its 30, if 30 its 60 ect. I get actual pressure plus the look of originality.
I run my '37 with original gauge and late model 250 engine. When really hot, the oil pressure drops to 25-30, other wise its pegged. I run 5-20 oil. Been running like this over 10,000 miles now.
joe
