1 members (Eileen), 99 guests, and 3 robots.
Topics128,079
Posts1,056,310
Members48,442
So, I blew a head gasket. Have removed everything required for removing head. Is this something that can be manhandled by 2 people? Any special tricks to make the job easier? Anyone in Orlando area know a reliable machine shop to recondition the head?
I believe it weighs 85 lbs. I would have left the manifold on to help break it loose. A hint for installing it, use a couple of guide bolts to hold the gasket in place.
1951 1 Ton Completed
I did break it loose with the manifold before I removed it.Where can you get guide bolts? That would help with installation.
Just cut the head off some cheap bolts the right length and thread. Just install them finger tight so they are easy to remove after you have several regular head bolts started.
Make sure you get them to magniflux test the head for cracks. I have had 2 heads in for testing and both had cracks. The head I had just bought was said to be pressure tested but as my machinist said at 30 pounds of pressure a cold head can hold air. Once the head heats up under use the crack can open up.
Now to search out another head for me…
Mark
P.S. they do weigh about 80-85 lbs so be careful lifting.
1952 GMC 9430 one ton pickup, a work in progress
1952 1-ton pictures on Photobucket
Riding in the Passing Lane
I used to pick them up myself at one time. If you are average strength & in good shape you can do it. 2 men no trouble at all. If you cut a slot in the guide bolt, you can use a screw driver to help remove it.
1972 Chevy c10 Cheyenne Super
Thanks for the help..
V
V Offline
I removed the head on my 216 by myself and learned my lesson well, I used a young strong SIL to help with the reinstall.
If your a one man band use a hoist or chain fall. Remove the rocker assembly and bolt the lift to the rocker tower bolt holes. Don't use the rocker bolts get some shorter ones.
I found it easier to reinstall the manifolds to the head on the bench then reinstalled the head as a unit.
Good luck
Dave
What I do is make a protective support on the fender. I climb in, stand on the frame and lift the head onto the platform.
Success...Attached chain as shown in attached photos and was easily lifted out.. ihttp://i166.photobucket.com/albums/u93/lynnebillh2/IMG_09841_zpshacqs8gp.jpgt
http://i166.photobucket.com/albums/u93/lynnebillh2/IMG_09831_zpsx00aaudo.jpg
http://i166.photobucket.com/albums/u93/lynnebillh2/IMG_09821_zpseinhxhso.jpg
As you can see from previous post I don't have this picture thing down yet...Still a newbie...
After the fact....if you have a friend that can help I like to turn the head cross ways and then, both of us learn over the fender and pick it up, walk forward with it.
...and as said, use guide bolts for sure when putting it back on. I used a couple lengths of "all thread" or threaded rod, as some call it and it worked just great.
Good luck Bill Hig. Let us know how things go.
Threaded rod seems the way to go...
