0 members (),
120
Mod | | | Forums66 Topics128,093 Posts1,056,474 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | Do any of you have experience driving in a 1/2 ton chevy with a hydraulic clutch? What are your impressions, and pros and cons. I have one and not sure if I want to repair it or ditch it. | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | if they are operating properly, they will work fine. sometime the master or the slave need rebuilding or replacing. neither is major. the other is that you may have a clutch that has seen better days and may need replacing. ron | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Those old hydraulic systems were good. They are simple & cheap to put a kit in the master & slave cyls. & will work good for many years. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Feb 2007 Posts: 230 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 230 | Got one in my '62. No problems. Frankly, since the clutch fork sticks out on the passenger side of the bell housing, hydraulic is the only option. | | | | | Joined: Apr 2014 Posts: 62 'Bolter | | 'Bolter Joined: Apr 2014 Posts: 62 | Do any of you have experience driving in a 1/2 ton chevy with a hydraulic clutch? What are your impressions, and pros and cons. I have one and not sure if I want to repair it or ditch it. I have one in my 1960 Apache and it works great. The JC engine code on my 235 six cylinder says its a heavy duty clutch (4 speed) if that makes any difference. Its a synchronized original trans. I can't say that there are any cons.
1961 Long Stepside Apache 10, original 235, 4 speed and 3:90 posi totally stock (owned 12 years) 1966 Chevelle (owned 53 years) | | | | | Joined: Apr 2014 Posts: 62 'Bolter | | 'Bolter Joined: Apr 2014 Posts: 62 | Correction: I have a '61, not a '60. They are the same hydraulic clutch.
1961 Long Stepside Apache 10, original 235, 4 speed and 3:90 posi totally stock (owned 12 years) 1966 Chevelle (owned 53 years) | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | | | |
