4 members (3800GUY, 3B, JW51, Lightholder's Dad), 125 guests, and 1 robot.
Topics128,130
Posts1,056,367
Members48,441
#1044275 07/23/2014 4:30 AM
Do any of you have experience driving in a 1/2 ton chevy with a hydraulic clutch? What are your impressions, and pros and cons. I have one and not sure if I want to repair it or ditch it.
if they are operating properly, they will work fine. sometime the master or the slave need rebuilding or replacing. neither is major.
the other is that you may have a clutch that has seen better days and may need replacing.
ron
Riding in the Passing Lane
Those old hydraulic systems were good. They are simple & cheap to put a kit in the master & slave cyls. & will work good for many years.
1972 Chevy c10 Cheyenne Super
Got one in my '62. No problems. Frankly, since the clutch fork sticks out on the passenger side of the bell housing, hydraulic is the only option.
I have one in my 1960 Apache and it works great. The JC engine code on my 235 six cylinder says its a heavy duty clutch (4 speed) if that makes any difference. Its a synchronized original trans. I can't say that there are any cons.
1961 Long Stepside Apache 10, original 235, 4 speed and 3:90 posi totally stock (owned 12 years)
1966 Chevelle (owned 53 years)
Correction: I have a '61, not a '60. They are the same hydraulic clutch.
yes
ron
