Originally Posted by LarryW
Oh yeah, I plan to prime the system with a drill to the oil pump.Larry
Excellent! Assembly lube, priming and a good flat tappet cam oil, such as Valvoline VR-1 Racing Oil, which is designed for flat tappet cams, and you should be good to go.
As for all the drama here.... life is short... don't worry, Be Happy thumbs_up
