| | | Forums66 Topics128,186 Posts1,057,315 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2012 Posts: 271 'Bolter | | 'Bolter Joined: May 2012 Posts: 271 | I have one but it will probably be a bit before i can pull the wheels. I agree a direct measurement will be best.
they way i did the calculation was to use the measurements rom the manual. If you take the difference between the center of the outer tires in the back and the mean of both tires int eh back- that should be the offset of a dually wheel. take that and add it to the center of the front tires and thats how much longer they make the axle so the same dual wheel will fit. that came to 66" I'm pretty confident it is correct because I found a measurement by soemone with a 1.5 ton and it was within 1/4" I think all that is different between the trucks front axle is something in the hub accounting for the small difference...
Hopefully I can take a true measurement in the next month or two. This really sucks not having the truck at my place where I can work on it even in any 15 or 30 min stretch I'm "free"
Tj | | | |
Entire Thread
Disc brakes for 1.5, and 2 ton trucks
| Grigg | 02/27/2011 8:25 PM |
Re: Disc brakes for 3/4, 1, 1.5, and 2 ton trucks
| Grigg | 02/27/2011 9:41 PM |
| Grigg | 02/27/2011 9:55 PM |
| Grigg | 02/27/2011 10:57 PM |
| kerry3 | 02/28/2011 12:45 PM |
| Murraydave | 02/28/2011 1:22 PM |
| Grigg | 02/28/2011 11:00 PM |
| MelodyM | 11/13/2016 10:21 PM |
| Grigg | 03/01/2011 3:21 PM |
| mojave b | 03/02/2011 4:53 AM |
| Grigg | 03/02/2011 1:19 PM |
| Grigg | 03/03/2011 2:24 PM |
| aggie jon | 03/11/2011 6:04 AM |
| Grigg | 03/29/2011 9:23 PM |
| JaysinSpaceman | 05/24/2011 10:36 PM |
| Grigg | 05/25/2011 12:42 AM |
| Grigg | 09/07/2011 6:58 PM |
| New_Ton | 10/27/2011 6:27 PM |
| Grigg | 10/28/2011 6:02 PM |
| Grampsold54 | 03/20/2011 4:43 PM |
| EdPruss | 04/06/2012 4:52 PM |
| faynelong | 04/14/2012 8:39 PM |
| King Kielbasa | 04/15/2012 3:13 AM |
| faynelong | 04/15/2012 2:34 PM |
| Tj_M | 06/09/2012 4:41 AM |
| Grigg | 06/11/2012 3:48 PM |
| Tj_M | 06/11/2012 6:33 PM |
| EdPruss | 11/06/2012 11:32 AM |
| bcgmc | 11/17/2015 5:19 AM |
| PAUL NOLZ | 12/22/2011 1:39 AM |
| zmaxmotorsports | 12/30/2014 1:04 AM |
| Grampsold54 | 01/08/2012 2:37 AM |
| Grigg | 01/08/2012 2:22 PM |
| Stoveboltkid | 03/13/2012 3:51 AM |
| Grigg | 03/13/2012 1:47 PM |
| Rippy | 04/04/2012 11:49 PM |
| Grigg | 04/05/2012 2:00 PM |
| Gric | 11/06/2012 11:21 PM |
| Grigg | 11/16/2012 1:50 PM |
To Grigg,
| Roadmarks | 12/19/2012 12:10 PM |
| Desmonaut | 12/19/2012 1:22 PM |
| Grigg | 12/19/2012 3:03 PM |
| Grigg | 12/19/2012 2:51 PM |
| Desmonaut | 12/19/2012 5:19 PM |
| Desmonaut | 12/19/2012 5:28 PM |
| Grigg | 12/19/2012 8:55 PM |
| Grigg | 01/08/2013 8:09 AM |
| Roadmarks | 01/26/2013 12:24 PM |
| Grigg | 01/26/2013 1:15 PM |
| Piston Farmer | 02/07/2013 4:22 PM |
| Grigg | 02/08/2013 7:34 AM |
| Tj_M | 02/08/2013 12:06 PM |
| Grigg | 02/12/2013 8:33 AM |
| Tj_M | 02/13/2013 10:37 PM |
| Grigg | 02/14/2013 8:38 AM |
| fclaridge | 04/04/2014 11:21 PM |
| PAUL NOLZ | 04/16/2014 5:30 AM |
| Grigg | 04/16/2014 1:15 PM |
| Errol | 09/25/2014 11:01 AM |
| Grigg | 09/25/2014 12:29 PM |
| don stocker | 09/25/2014 12:30 PM |
| Errol | 09/26/2014 1:12 PM |
| Errol | 09/28/2014 3:14 PM |
| Grigg | 09/29/2014 2:10 PM |
| 67C50Pickup | 09/29/2014 10:00 PM |
| Grigg | 09/29/2014 11:38 PM |
| 67C50Pickup | 10/04/2014 4:05 AM |
| 67C50Pickup | 10/04/2014 2:55 PM |
| Nate_L | 11/15/2014 12:41 AM |
| 5 Window 9434 | 11/15/2014 12:13 PM |
| Nate_L | 11/16/2014 2:12 AM |
| Nate_L | 11/15/2014 12:43 AM |
| Wayne67vert | 11/15/2014 1:32 AM |
| FASTRED68 | 01/14/2015 2:15 PM |
| Grigg | 01/14/2015 4:08 PM |
| FASTRED68 | 01/14/2015 9:35 PM |
| Grigg | 01/14/2015 10:11 PM |
| FASTRED68 | 01/14/2015 10:46 PM |
| FASTRED68 | 01/14/2015 10:47 PM |
| FASTRED68 | 01/22/2015 2:10 PM |
| Grigg | 01/22/2015 3:16 PM |
| cleiser25 | 05/15/2015 4:19 PM |
| Craig1948RK | 08/09/2015 7:28 PM |
| Grigg | 08/10/2015 3:13 PM |
| baldeagle | 08/09/2015 9:34 PM |
| koolkar | 10/02/2015 5:47 AM |
| Grigg | 10/02/2015 1:16 PM |
| koolkar | 10/03/2015 6:46 PM |
| Grigg | 11/17/2015 5:23 AM |
| bcgmc | 11/17/2015 5:24 PM |
| Grigg | 11/17/2015 6:16 PM |
| bcgmc | 11/18/2015 5:18 PM |
| Grigg | 11/18/2015 5:33 PM |
| bcgmc | 11/18/2015 6:03 PM |
| Grigg | 11/18/2015 6:49 PM |
| bcgmc | 11/19/2015 5:11 PM |
| Grigg | 11/19/2015 5:14 PM |
| bcgmc | 11/19/2015 5:18 PM |
| Grigg | 11/19/2015 5:22 PM |
| bcgmc | 11/19/2015 6:09 PM |
| DavidBraley | 02/24/2016 7:23 AM |
| danzimbric | 03/31/2016 11:20 AM |
| Mike B | 03/31/2016 7:04 PM |
| Tango | 09/04/2016 4:29 PM |
| 40_chevy | 09/16/2016 4:18 PM |
| Grigg | 09/17/2016 4:32 AM |
| 40_chevy | 02/03/2018 8:37 AM |
| Grigg | 02/03/2018 12:33 PM |
| 40_chevy | 02/03/2018 6:21 PM |
| Mike1950AD2ton | 04/28/2018 2:35 AM |
| smokejumper | 05/10/2018 5:49 PM |
| Grigg | 05/10/2018 6:47 PM |
| Gooberdog | 05/15/2018 2:19 PM |
| Grigg | 05/15/2018 6:16 PM |
| Gooberdog | 05/16/2018 12:47 PM |
| Aaron S | 09/03/2018 7:37 PM |
| Grigg | 09/03/2018 11:01 PM |
| Aaron S | 09/04/2018 1:05 AM |
| 54 c500 | 11/05/2018 1:30 PM |
| Philipj | 01/13/2019 3:33 PM |
| Steve-W | 01/16/2019 4:43 PM |
| Justhorsenround | 01/16/2019 4:52 PM |
| TooMany2count | 02/04/2019 5:47 PM |
| Grigg | 02/04/2019 8:36 PM |
| prubah | 05/07/2019 1:46 AM |
| campbell45 | 06/20/2019 7:49 PM |
| campbell45 | 06/25/2019 11:43 AM |
| tclederman | 06/25/2019 12:29 PM |
| Grigg | 06/25/2019 2:38 PM |
| campbell45 | 06/25/2019 6:05 PM |
| 1930 Charlie | 07/08/2019 12:25 PM |
| 1Ton_tommy | 07/30/2019 7:48 PM |
| Wayne67vert | 08/01/2019 2:25 PM |
| sweepleader | 08/01/2019 4:14 PM |
| 1Ton_tommy | 08/05/2019 8:40 PM |
| sweepleader | 08/05/2019 9:28 PM |
| TSMMFG | 08/21/2019 9:58 PM |
| Grigg | 08/22/2019 1:21 AM | |
