0 members (),
143
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,189 Posts1,057,337 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#80361 08/23/2007 2:17 PM | Joined: Mar 2007 Posts: 81 'Bolter | | 'Bolter Joined: Mar 2007 Posts: 81 | I finally had some time to look at my truck. Here is what I did: The fuel pooring out inside the cab as I turned left was caused by a corroded hose on the filler pipe, actually is was the little vent hose that was corroded. Replaced filler and vent hoses.
For the cutting out issue, I crawled under my truck and notice a shut off valve under the tank and a rubber hose connecting it to the metal fuel line. It was pretty weather worn. I turned off the valve (I was amazed it worked) and cut off the old hose. Installed a new hose and turned on the valve and let it drain in a bucket. Some dirt or rust came out at first then is was flowing clean and freely. I installed the hose to the fuel line. Started the truck and let it completly warm up then I went for a drive. It never cut out on me and it idles with the choke wide open.
I sure hope that the shut off valve was partially blocked by this dirt (or rust) but I am skeptical. Only time will tell.
I also moved the fuel line going to the carburator farther away from the t-stat housing and radiator hoses.
52 Chevy 3100 5 Window, LS Swap, 4spd Auto, Vintage Air AC / Heat, CPP Power Front Disc Brake Conversion with bearing upgrade, Power Steering Conversion, LED Tail Lights
Entire Thread
Help!!! Engine Cutting Out, I,m Stumped.
| Rcimp | 07/24/2007 2:05 AM |
Re: Help!!! Engine Cutting Out, I,m Stumped.
| waldo53 | 07/24/2007 2:56 AM |
| WHO, ME ? | 07/24/2007 3:24 AM |
| Grigg | 07/24/2007 3:34 AM |
| atomarc | 07/24/2007 5:18 AM |
| Darin367 | 07/24/2007 5:47 AM |
| PaulyBuilt, Inc. | 07/24/2007 6:41 AM |
| dale937 | 07/24/2007 1:25 PM |
| Rcimp | 07/24/2007 1:50 PM |
| waldo53 | 07/24/2007 5:20 PM |
| Delux | 07/24/2007 9:19 PM |
| Rcimp | 07/24/2007 9:25 PM |
| Slickriffs | 07/25/2007 12:07 AM |
| Rcimp | 07/25/2007 3:37 AM |
| atomarc | 07/25/2007 4:00 AM |
| Rcimp | 07/25/2007 1:48 PM |
| atomarc | 07/25/2007 4:06 PM |
| Rcimp | 07/26/2007 2:03 PM |
| atomarc | 07/26/2007 4:31 PM |
| waldo53 | 07/26/2007 6:16 PM |
| Pre '68 Dave | 07/26/2007 8:51 PM |
| beltfed | 07/26/2007 10:20 PM |
| Rcimp | 07/27/2007 2:39 PM |
| Justin Rubsam | 07/28/2007 7:58 PM |
| Rcimp | 07/29/2007 2:47 PM |
| 1951Chevy1Ton | 07/30/2007 4:48 AM |
| D Sinclair | 07/30/2007 5:28 AM |
| Rcimp | 07/30/2007 1:56 PM |
| ApacheManSlim60 | 07/31/2007 7:11 AM |
| Rcimp | 08/23/2007 2:17 PM |
| wyldehare | 08/24/2007 7:35 AM |
| Organbuilder | 08/24/2007 12:07 PM | |
