0 members (),
143
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,189 Posts1,057,337 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#80333 07/24/2007 2:56 AM | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | Sounds like a fuel starvation problem. A vacuum leak would make the engine run rough, even at idle. Since you have a new fuel pump and fuel filter you've eliminated the usual culprits. It could be the line from the tank to the pump is clogged with something but I'm not sure how to check this other than disconnecting the line at the inlet to the fuel pump and see if fuel is running out freely. The only other thing I can think of is maybe a carb float problem. Hopefully someone else can come up with some other possible causes. Good luck!! | | | |
Entire Thread
Help!!! Engine Cutting Out, I,m Stumped.
| Rcimp | 07/24/2007 2:05 AM |
Re: Help!!! Engine Cutting Out, I,m Stumped.
| waldo53 | 07/24/2007 2:56 AM |
| WHO, ME ? | 07/24/2007 3:24 AM |
| Grigg | 07/24/2007 3:34 AM |
| atomarc | 07/24/2007 5:18 AM |
| Darin367 | 07/24/2007 5:47 AM |
| PaulyBuilt, Inc. | 07/24/2007 6:41 AM |
| dale937 | 07/24/2007 1:25 PM |
| Rcimp | 07/24/2007 1:50 PM |
| waldo53 | 07/24/2007 5:20 PM |
| Delux | 07/24/2007 9:19 PM |
| Rcimp | 07/24/2007 9:25 PM |
| Slickriffs | 07/25/2007 12:07 AM |
| Rcimp | 07/25/2007 3:37 AM |
| atomarc | 07/25/2007 4:00 AM |
| Rcimp | 07/25/2007 1:48 PM |
| atomarc | 07/25/2007 4:06 PM |
| Rcimp | 07/26/2007 2:03 PM |
| atomarc | 07/26/2007 4:31 PM |
| waldo53 | 07/26/2007 6:16 PM |
| Pre '68 Dave | 07/26/2007 8:51 PM |
| beltfed | 07/26/2007 10:20 PM |
| Rcimp | 07/27/2007 2:39 PM |
| Justin Rubsam | 07/28/2007 7:58 PM |
| Rcimp | 07/29/2007 2:47 PM |
| 1951Chevy1Ton | 07/30/2007 4:48 AM |
| D Sinclair | 07/30/2007 5:28 AM |
| Rcimp | 07/30/2007 1:56 PM |
| ApacheManSlim60 | 07/31/2007 7:11 AM |
| Rcimp | 08/23/2007 2:17 PM |
| wyldehare | 08/24/2007 7:35 AM |
| Organbuilder | 08/24/2007 12:07 PM | |
