Originally Posted by Joe H
Valve seal are likely dried up. Have you had it out on the road and run up pretty hard, it might help loosen rings if they are stuck or not seated. Give it a good 50 or 60 mile hard run, if it still smokes, pull the plugs and see if one or more are different from the rest. Also, check and see where the PCV valve is hooked up and if there is a baffle in the valve cover, it could be sucking oil, the line into the carburetor will be oily.
I can only say that the head was fully serviced then stored for several months.
1953 Chevy 153A 3/4-ton
Working on my project since 2015
Follow along in my DITY
