| | | Forums66 Topics128,090 Posts1,056,369 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,826 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,826 | Yes, that's definitely the wrong carburetor. If you choose to continue to run it, adjust the choke cover to just barely close the plate with the engine stopped, cold and the throttle held halfway open, then wire 12 volts to the connector on the cover through an oil pressure sensing switch so the choke coil is only heated with the engine running. If the engine happens to stall with 12V applied to the choke, the valve will open prematurely.
Then make sure intake manifold vacuum is plumbed to the choke release canister, the round device visible at the lower left of your picture. That partially releases the choke plate once the engine starts, to prevent stalling from over-choking. Don't attempt to adjust idle speed or mixture until the engine is fully warmed up and the choke plate is completely vertical in the airstream. Jerry
Entire Thread
In line 6, 250 Chevy
| glennj3 | 11/24/2025 5:25 AM |
Re: In line 6, 250 Chevy
| Joe H | 11/24/2025 2:19 PM |
| glennj3 | 12/08/2025 2:33 AM |
| Hotrod Lincoln | 11/24/2025 4:10 PM |
| BC59 | 11/24/2025 9:03 PM |
| glennj3 | 11/30/2025 1:17 AM |
| Tronman | 11/25/2025 11:30 PM |
| Hotrod Lincoln | 11/28/2025 5:14 PM |
| glennj3 | 11/30/2025 1:19 AM |
| Hotrod Lincoln | 11/30/2025 2:53 AM |
| glennj3 | 12/04/2025 10:17 PM |
| Hotrod Lincoln | 12/04/2025 10:33 PM |
| Joe H | 12/05/2025 2:34 PM |
| glennj3 | 12/07/2025 1:53 PM |
| Joe H | 12/07/2025 2:11 PM |
| Tronman | 12/08/2025 4:55 AM |
| glennj3 | 12/09/2025 10:54 PM |
| Hotrod Lincoln | 12/09/2025 11:15 PM |
| glennj3 | 12/10/2025 4:33 PM |
| Bill Hanlon | 12/10/2025 2:38 PM |
| glennj3 | 12/10/2025 10:33 PM |
| Hotrod Lincoln | 12/10/2025 11:27 PM |
| glennj3 | 12/11/2025 4:12 AM |
| Joe H | 12/11/2025 2:31 PM |
| glennj3 | 12/11/2025 5:10 PM |
| glennj3 | 01/02/2026 11:37 PM |
| Bill Hanlon | 01/02/2026 11:54 PM |
| glennj3 | 01/03/2026 5:10 AM |
| Phak1 | 01/03/2026 1:58 AM |
| glennj3 | 01/03/2026 5:20 AM |
| WICruiser | 01/03/2026 1:09 PM |
| Joe H | 01/03/2026 2:24 PM |
| glennj3 | 01/03/2026 5:37 PM |
| klhansen | 01/03/2026 6:08 PM |
| glennj3 | 01/04/2026 5:59 PM |
| Hotrod Lincoln | 01/03/2026 6:33 PM |
| glennj3 | 01/04/2026 5:58 PM |
| Hotrod Lincoln | 01/04/2026 6:11 PM |
| glennj3 | 01/04/2026 8:51 PM |
| klhansen | 01/04/2026 9:44 PM |
| glennj3 | 01/06/2026 3:39 AM |
| Hotrod Lincoln | 01/04/2026 11:34 PM | |
