0 members (),
74
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2021 Posts: 6,722 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,722 | Drove Ol' Roy to work today and covered the same stretch of road where the backfire first manifested itself. I didn't lose power up the long grade and it didn't blow a stinker when I reached the top.
The carb float pin hasn't fallen out so I must have installed it in the right orientation.
Truck is getting its usual 12 mpg so it looks like everything is back to normal except for the following issue that didn't exist prior to all of this nonsense.
1. When I remove the gas cap, it is vacuum sucked to the filler neck. It is a one year old, vented Motorad cap - the same one sold by everybody, including under the Gates brand name. What happened? The tank is not pressurized. A vacuum is being created in the tank, I assume by the fuel pump. What should I do about it? Drill out the purge valve on the underside of the gas cap?
1950 Chevrolet 3100 (Ol' Roy)
Entire Thread
Backfiring, Leaking Carb, etc...
| Otto Skorzeny | 01/25/2024 9:07 PM |
Re: Backfiring, Leaking Carb, etc...
| Hotrod Lincoln | 01/25/2024 9:52 PM |
| Otto Skorzeny | 01/25/2024 9:56 PM |
| Hotrod Lincoln | 01/25/2024 10:03 PM |
| carbking | 01/25/2024 11:45 PM |
| Otto Skorzeny | 01/25/2024 11:49 PM |
| Hotrod Lincoln | 01/25/2024 11:52 PM |
| Wrenchbender Ret. | 01/26/2024 4:32 PM |
| 52Carl | 01/26/2024 7:18 PM |
| Otto Skorzeny | 01/26/2024 10:03 PM |
| klhansen | 01/26/2024 10:10 PM |
| Otto Skorzeny | 01/27/2024 12:27 AM |
| BC59 | 01/27/2024 4:56 AM |
| JW51 | 01/27/2024 12:56 PM |
| Jon G | 01/27/2024 3:46 PM |
| Jon G | 01/27/2024 5:55 PM |
| JW51 | 01/27/2024 6:33 PM |
| klhansen | 01/27/2024 6:43 PM |
| Otto Skorzeny | 01/27/2024 8:03 PM |
| Otto Skorzeny | 01/27/2024 8:06 PM |
| Jon G | 01/28/2024 4:23 AM |
| Otto Skorzeny | 01/28/2024 4:28 AM |
| Otto Skorzeny | 01/29/2024 9:25 PM |
| Jon G | 01/29/2024 10:13 PM |
| Otto Skorzeny | 01/29/2024 10:18 PM |
| Jon G | 01/29/2024 11:14 PM |
| Otto Skorzeny | 01/29/2024 11:39 PM |
| Otto Skorzeny | 01/30/2024 8:14 PM |
| Otto Skorzeny | 01/30/2024 8:17 PM |
| carbking | 01/31/2024 1:00 AM |
| Otto Skorzeny | 01/31/2024 1:07 AM |
| Bill Hanlon | 01/31/2024 3:22 AM | |
