8 members (Hotrod Lincoln, carbking, tclederman, Bill Hanlon, 49choptop, Guitplayer, John L., Otto Skorzeny),
125
Mod | | | Forums66 Topics128,042 Posts1,055,501 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2021 Posts: 6,716 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,716 | Interestingly, the pin and float were still in position , not hanging loose.
I had to remove the pin and float to re-install the valve and spring.
What happened inside the carburetor to cause the valve and spring to fall out is a mystery to me. Debris in the bad fuel? Backfire coughing through the carb? Pretty weird.
1950 Chevrolet 3100 (Ol' Roy)
Entire Thread
Backfiring, Leaking Carb, etc...
| Otto Skorzeny | 01/25/2024 9:07 PM |
Re: Backfiring, Leaking Carb, etc...
| Hotrod Lincoln | 01/25/2024 9:52 PM |
| Otto Skorzeny | 01/25/2024 9:56 PM |
| Hotrod Lincoln | 01/25/2024 10:03 PM |
| carbking | 01/25/2024 11:45 PM |
| Otto Skorzeny | 01/25/2024 11:49 PM |
| Hotrod Lincoln | 01/25/2024 11:52 PM |
| Wrenchbender Ret. | 01/26/2024 4:32 PM |
| 52Carl | 01/26/2024 7:18 PM |
| Otto Skorzeny | 01/26/2024 10:03 PM |
| klhansen | 01/26/2024 10:10 PM |
| Otto Skorzeny | 01/27/2024 12:27 AM |
| BC59 | 01/27/2024 4:56 AM |
| JW51 | 01/27/2024 12:56 PM |
| Jon G | 01/27/2024 3:46 PM |
| Jon G | 01/27/2024 5:55 PM |
| JW51 | 01/27/2024 6:33 PM |
| klhansen | 01/27/2024 6:43 PM |
| Otto Skorzeny | 01/27/2024 8:03 PM |
| Otto Skorzeny | 01/27/2024 8:06 PM |
| Jon G | 01/28/2024 4:23 AM |
| Otto Skorzeny | 01/28/2024 4:28 AM |
| Otto Skorzeny | 01/29/2024 9:25 PM |
| Jon G | 01/29/2024 10:13 PM |
| Otto Skorzeny | 01/29/2024 10:18 PM |
| Jon G | 01/29/2024 11:14 PM |
| Otto Skorzeny | 01/29/2024 11:39 PM |
| Otto Skorzeny | 01/30/2024 8:14 PM |
| Otto Skorzeny | 01/30/2024 8:17 PM |
| carbking | 01/31/2024 1:00 AM |
| Otto Skorzeny | 01/31/2024 1:07 AM |
| Bill Hanlon | 01/31/2024 3:22 AM | |
