| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,881 | The thick part of the clutch disc center hub with the torsion springs in it MUST be pointed away from the flywheel. Otherwise, the springs drag on the flywheel attaching bolt heads. Jerry
