Winter is Coming
Hey, that stuff all needs to be done eventually. I know what you mean about a diversion. I put some tough body work aside for a while and worked on stuff that was easier.
Nice job on the horns.
Kevin 1951 Chevy 3100 work truck Follow this saga in Project Journal Photos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together.
