At the back end of this transmission where the drive shaft attaches, normally there is a U Joint but this one is closed.
Would I need to remove the cover ? Is there a U Joint inside of that cover?
1953 Chevy 153A 3/4-ton
Working on my project since 2015
Follow along in my DITY
