I vote lead it. I leaded mine on my 1959 apache, if you can understand how to solder you can lead those pits and small holes. I use bees wax as as the paddle lubricant and the you can achieve a very smooth surface. The tricky part is tinning the base metal but a tinning compound makes that fairly easy too.
1959 Apache 31
