| | | Forums66 Topics128,189 Posts1,057,337 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I don't have enough measurements yet to know if the P-30 spindle swap (8 lug) is useful for the 1 ton DRW trucks. You can measure your original axle width and compare with measurements given earlier for what a 2 ton axle with 8 lug P-30 spindles on it would measure.
(I'm sure it does not work with single wheel 8 lug stuff on P-30 spindles on 2 ton I-beam, it's still overly wide...) With luck your measurements will workout on the DRW version, I have not ventured down that path to know.
These P-30 spindles do not fit on a 3/4 or 1 ton axle, but the 2 ton axle beam (48-54) does bolt under the same model 1 ton trucks.
The risk is not having the axle welded properly, that's up to you. It's not terribly difficult for a competent welder and with some careful alignment of the pieces before welding. Altogether though it's a lot of work and time to cut, prep, weld, and pretty up a welded axle beam. The P-30 spindle swap on a 2 ton axle beam can be done in an afternoon once you have the parts and pieces at hand and clean, reaming some bushings is not tricky or difficult, low risk. | | | |
Entire Thread
Disc brakes for 1.5, and 2 ton trucks
| Grigg | 02/27/2011 8:25 PM |
Re: Disc brakes for 3/4, 1, 1.5, and 2 ton trucks
| Grigg | 02/27/2011 9:41 PM |
| Grigg | 02/27/2011 9:55 PM |
| Grigg | 02/27/2011 10:57 PM |
| kerry3 | 02/28/2011 12:45 PM |
| Murraydave | 02/28/2011 1:22 PM |
| Grigg | 02/28/2011 11:00 PM |
| MelodyM | 11/13/2016 10:21 PM |
| Grigg | 03/01/2011 3:21 PM |
| mojave b | 03/02/2011 4:53 AM |
| Grigg | 03/02/2011 1:19 PM |
| Grigg | 03/03/2011 2:24 PM |
| aggie jon | 03/11/2011 6:04 AM |
| Grigg | 03/29/2011 9:23 PM |
| JaysinSpaceman | 05/24/2011 10:36 PM |
| Grigg | 05/25/2011 12:42 AM |
| Grigg | 09/07/2011 6:58 PM |
| New_Ton | 10/27/2011 6:27 PM |
| Grigg | 10/28/2011 6:02 PM |
| Grampsold54 | 03/20/2011 4:43 PM |
| EdPruss | 04/06/2012 4:52 PM |
| faynelong | 04/14/2012 8:39 PM |
| King Kielbasa | 04/15/2012 3:13 AM |
| faynelong | 04/15/2012 2:34 PM |
| Tj_M | 06/09/2012 4:41 AM |
| Grigg | 06/11/2012 3:48 PM |
| Tj_M | 06/11/2012 6:33 PM |
| EdPruss | 11/06/2012 11:32 AM |
| bcgmc | 11/17/2015 5:19 AM |
| PAUL NOLZ | 12/22/2011 1:39 AM |
| zmaxmotorsports | 12/30/2014 1:04 AM |
| Grampsold54 | 01/08/2012 2:37 AM |
| Grigg | 01/08/2012 2:22 PM |
| Stoveboltkid | 03/13/2012 3:51 AM |
| Grigg | 03/13/2012 1:47 PM |
| Rippy | 04/04/2012 11:49 PM |
| Grigg | 04/05/2012 2:00 PM |
| Gric | 11/06/2012 11:21 PM |
| Grigg | 11/16/2012 1:50 PM |
To Grigg,
| Roadmarks | 12/19/2012 12:10 PM |
| Desmonaut | 12/19/2012 1:22 PM |
| Grigg | 12/19/2012 3:03 PM |
| Grigg | 12/19/2012 2:51 PM |
| Desmonaut | 12/19/2012 5:19 PM |
| Desmonaut | 12/19/2012 5:28 PM |
| Grigg | 12/19/2012 8:55 PM |
| Grigg | 01/08/2013 8:09 AM |
| Roadmarks | 01/26/2013 12:24 PM |
| Grigg | 01/26/2013 1:15 PM |
| Piston Farmer | 02/07/2013 4:22 PM |
| Grigg | 02/08/2013 7:34 AM |
| Tj_M | 02/08/2013 12:06 PM |
| Grigg | 02/12/2013 8:33 AM |
| Tj_M | 02/13/2013 10:37 PM |
| Grigg | 02/14/2013 8:38 AM |
| fclaridge | 04/04/2014 11:21 PM |
| PAUL NOLZ | 04/16/2014 5:30 AM |
| Grigg | 04/16/2014 1:15 PM |
| Errol | 09/25/2014 11:01 AM |
| Grigg | 09/25/2014 12:29 PM |
| don stocker | 09/25/2014 12:30 PM |
| Errol | 09/26/2014 1:12 PM |
| Errol | 09/28/2014 3:14 PM |
| Grigg | 09/29/2014 2:10 PM |
| 67C50Pickup | 09/29/2014 10:00 PM |
| Grigg | 09/29/2014 11:38 PM |
| 67C50Pickup | 10/04/2014 4:05 AM |
| 67C50Pickup | 10/04/2014 2:55 PM |
| Nate_L | 11/15/2014 12:41 AM |
| 5 Window 9434 | 11/15/2014 12:13 PM |
| Nate_L | 11/16/2014 2:12 AM |
| Nate_L | 11/15/2014 12:43 AM |
| Wayne67vert | 11/15/2014 1:32 AM |
| FASTRED68 | 01/14/2015 2:15 PM |
| Grigg | 01/14/2015 4:08 PM |
| FASTRED68 | 01/14/2015 9:35 PM |
| Grigg | 01/14/2015 10:11 PM |
| FASTRED68 | 01/14/2015 10:46 PM |
| FASTRED68 | 01/14/2015 10:47 PM |
| FASTRED68 | 01/22/2015 2:10 PM |
| Grigg | 01/22/2015 3:16 PM |
| cleiser25 | 05/15/2015 4:19 PM |
| Craig1948RK | 08/09/2015 7:28 PM |
| Grigg | 08/10/2015 3:13 PM |
| baldeagle | 08/09/2015 9:34 PM |
| koolkar | 10/02/2015 5:47 AM |
| Grigg | 10/02/2015 1:16 PM |
| koolkar | 10/03/2015 6:46 PM |
| Grigg | 11/17/2015 5:23 AM |
| bcgmc | 11/17/2015 5:24 PM |
| Grigg | 11/17/2015 6:16 PM |
| bcgmc | 11/18/2015 5:18 PM |
| Grigg | 11/18/2015 5:33 PM |
| bcgmc | 11/18/2015 6:03 PM |
| Grigg | 11/18/2015 6:49 PM |
| bcgmc | 11/19/2015 5:11 PM |
| Grigg | 11/19/2015 5:14 PM |
| bcgmc | 11/19/2015 5:18 PM |
| Grigg | 11/19/2015 5:22 PM |
| bcgmc | 11/19/2015 6:09 PM |
| DavidBraley | 02/24/2016 7:23 AM |
| danzimbric | 03/31/2016 11:20 AM |
| Mike B | 03/31/2016 7:04 PM |
| Tango | 09/04/2016 4:29 PM |
| 40_chevy | 09/16/2016 4:18 PM |
| Grigg | 09/17/2016 4:32 AM |
| 40_chevy | 02/03/2018 8:37 AM |
| Grigg | 02/03/2018 12:33 PM |
| 40_chevy | 02/03/2018 6:21 PM |
| Mike1950AD2ton | 04/28/2018 2:35 AM |
| smokejumper | 05/10/2018 5:49 PM |
| Grigg | 05/10/2018 6:47 PM |
| Gooberdog | 05/15/2018 2:19 PM |
| Grigg | 05/15/2018 6:16 PM |
| Gooberdog | 05/16/2018 12:47 PM |
| Aaron S | 09/03/2018 7:37 PM |
| Grigg | 09/03/2018 11:01 PM |
| Aaron S | 09/04/2018 1:05 AM |
| 54 c500 | 11/05/2018 1:30 PM |
| Philipj | 01/13/2019 3:33 PM |
| Steve-W | 01/16/2019 4:43 PM |
| Justhorsenround | 01/16/2019 4:52 PM |
| TooMany2count | 02/04/2019 5:47 PM |
| Grigg | 02/04/2019 8:36 PM |
| prubah | 05/07/2019 1:46 AM |
| campbell45 | 06/20/2019 7:49 PM |
| campbell45 | 06/25/2019 11:43 AM |
| tclederman | 06/25/2019 12:29 PM |
| Grigg | 06/25/2019 2:38 PM |
| campbell45 | 06/25/2019 6:05 PM |
| 1930 Charlie | 07/08/2019 12:25 PM |
| 1Ton_tommy | 07/30/2019 7:48 PM |
| Wayne67vert | 08/01/2019 2:25 PM |
| sweepleader | 08/01/2019 4:14 PM |
| 1Ton_tommy | 08/05/2019 8:40 PM |
| sweepleader | 08/05/2019 9:28 PM |
| TSMMFG | 08/21/2019 9:58 PM |
| Grigg | 08/22/2019 1:21 AM | |
